Exhaust back pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, May 16, 2019.
  1. insanityeight
    insanityeight Light Load Member
    287
    111
    Jul 26, 2013
    birmingham al
    Been reading alot amd just curious as to what yall think. Have a paccar mx 13 with certain parts fell off. My exhaust back pressure valve behind turbo is bad and ive ran it with it wired in open position with no noticeable issues. Everything i read leads me to believe back pressure behind turbo is absolutely not needed even on a newer emissions engine. Any thought?? Thanks in advance and happy trucking
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    The EBP valve on an MX is used for regeneration only to create back pressure which in turn creates heat to maintain and build exhaust temps. It serves no other purpose. Since your DPF fell off.......you dont need it. The BPV valve is needed on any MX engine still meeting emissions compliance.
    ISX uses VGT for back pressure. MX uses the same VGT but only uses the VGT for boost control, not regeneration. MX has a much lower VGT failure rate due to the lower duty cycle. Plus the EGR coolers dont leak coolant and hang up the sliding nozzle ring.
  4. insanityeight
    287
    111
    Jul 26, 2013
    birmingham al
    Thanks alot dor the valuable input.
    Goodysnap Thanks this.
  5. Rookie o/o
    Rookie o/o Bobtail Member
    13
    When you say the bpv valve is bad, is it leaking mine is. And how do you wire it open? Thanks
  6. Mountainman82
    Mountainman82 Bobtail Member
    7
    Does anyone know how much back pressure a MX13 can handle?
