Now, I’m pretty sure this would be considered excessive after running 65 to 70 20k load, pretty flat terrain. Opinions?
[GALLERY=][/GALLERY]
oil pressure is around 25 idle and 42 running around 1500-1700 rpm. What’s your thoughts?
Excessive blow by for bend new D60 reman?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by magellan, Jan 6, 2022.
thats nothing compared to a buddies 30 thousand dollar cat rebuild from cat last year. I even pulled his oil fill and dipstick and it was chuggin worse than yours.He went out of his mind. anyhow he called cat and they told him its gonna be that way till the rings set or some bs. He ran it hard for next 2 weeks and i think by the 3rd week, there was zero blow by. Well not zero, but very minimal. Your always gonna have some. So im gonna say yeah thats normal. gonna have to run it hard dude. takes more than one hard pull. Takes a couple weeks for some people depending miles and how hard you run it
lwlevens and Rideandrepair Thank this. -
Rideandrepair Thanks this.
rings are not set at 20k your oil pres is low mine runs about 55 on the road
Rideandrepair Thanks this. -
I was under the impression that it would continually use oil until the rings set. I went through about 2 gallons and she stopped using oil, that’s why I figured they had set.
I know the blow by wasn’t nearly this bad, my fuel mileage was better, and pressure was higher. Something has changed.
After install, (250 miles in) an injector failed due to a screw that had backed out from the factory. The oil mixed with quite fuel a bit of fuel and Im wondering if some damage was done in that process.Rideandrepair Thanks this. -
yes mines a Detroit dd3 idel oil pres around 25 hot hsa around 90 thous on in frame
lwlevens, Rideandrepair, Magoo1968 and 1 other person Thank this.
Boss finds that the money he spends on breaking engine in on the dyno is well worth it.. he swears his chances of a oil burner are way higher trying to break engine in with our 20 k outbound loads . Engines need to work hard at the beginning of their life it seems.
Rideandrepair and Don379 Thank this. -
It takes 70k at least of Highway running to seal rings on a 60. They’ve been known to take longer. Once the fuel economy jumps up, almost 1 mpg, you’ll know they’re sealed up. As far as oil pressure. It’s good. Only time it’s over 50lbs.is after an oil change, or cold start.
lwlevens Thanks this.
