Every trailer I connect to is not straight in my right mirror
Discussion in 'Ask An Owner Operator' started by JayTemp94, Dec 2, 2020.
  1. JayTemp94
    JayTemp94 Bobtail Member
    9
    Dec 2, 2020
    Has anybody had this issue?
  3. Spyro2112
    Spyro2112 Medium Load Member
    602
    412
    Mar 17, 2018
    Yep doglegged, alignment will fix that, .......company equipment
  4. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    "Every trailer"?
    Adjust your mirror
  5. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    Yep, simple. It's an illusion created by the angle of your mirror if it's every trailer.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    Are you #### eyed?
    Lite bug and God prefers Diesels Thank this.
  7. JC1971
    JC1971 Road Train Member
    2,607
    9,297
    Jul 29, 2013
    L.A.
    When you're riding the lane marking on the left and the right side of the trailer is on the right line and your company doesn't want to fix it, time for another company.
  8. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,738
    Mar 19, 2018
    Nashville
    If you mean the trailer appears to be leaning to one side yes, I have had this issue before. You look in one mirror and it seems normal, then the other mirror and it seems to be off. Optical illusion of some kind.
  9. shatteredsquare
    shatteredsquare Road Train Member
    1,398
    1,825
    May 23, 2014
    middle dirt
    passenger mirror tells you where you are, driver mirror tells you where you're going. you have to consider both for it to work out ok. kind of like male and female. also one is always confusing you, and never quite comfortable enough
    RubyEagle, Trucker61016 and 86scotty Thank this.
  10. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    Take a few minutes to adjust mirrors to your comfort. Losen mounting bolts so not twisting, distorting mirrors, bending arms etc.
    Driving, and backing, is ssoooo much easier when mirrors are set to my natural, comfortable seat position. A quick glance and I see what I should be seeing vs leaning to accommodate mirror position. This is amplified when each mirror is in different position, both wrong, leaning back 'n forth to accommodate each wrong mirror position.
    Stay safe :occasion5:
  11. SmallPackage
    5,274
    16,448
    Dec 20, 2019
    Marion Texas
    One thing I’ve noticed messing with lots of different trucks over the years is mirror brands and quality are different. Some will distort/twist images and some will make distances shorter or longer. Back up to a dock and you know what I mean. Some styles and brands put the rear corner dead nuts on the dock while others make it look like you still have 3 ft to go or you hit it 3 ft ago.
    Worst mirrors are the ones IHC used on the S-series trucks. Always dull and dim glass and made you look like you had a yard to go behind you when you hit.
    Best ones were Freightliner. The wedged back stainless steel ones they used on everything from the 80’s till they went plastic. Dead nuts and bright clear glass on those.
