evaporator coil
Discussion in 'Freightliner Forum' started by jklopez09, Sep 3, 2014.
  1. jklopez09
    jklopez09 Bobtail Member
    24
    Apr 1, 2013
    Does anyone know the best way to get to the evaporator coil in a century?
  3. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Never done one in a freightshaker. If you're somewhat mechanically inclined it wont be too bad. Just follow the a/c lines running up to the firewall and into the cab. From there I would just start removing dash panels and dig it out of there. Start near passenger side footwell. That's where it's located. Why do you need to get to the evaporator?
  4. jklopez09
    24
    Apr 1, 2013
    I think it might be leaking freon
  5. asavage1576
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Oh ok got ya. Just a quick tip that an old timer showed me at work one time. If the system is empty with no refrigerant in it, and you hook up your machine and start pulling a vacuum on the system, use a long piece of tubing as listening device and run it along the lines and around a/c components and listen for a sucking sound. Also, filling the system with nitrogen and using soapy water works really well. However, not every DIY has a nitrogen set up.
  6. jklopez09
    24
    Apr 1, 2013
    Thanks, I'll try that.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    You can rig up an A/C fitting to a regulator. 50 psi of shop air and soapy water has found more leaks for me than the $350 Snap-On leak detector. Just replace the dryer and pull a good vacuum on it when you're done.
