Estimate on Shop Hours to Replace Volvo 780 radiator
Discussion in 'Ask An Owner Operator' started by radarmonkey, May 14, 2017.
  1. radarmonkey
    radarmonkey Bobtail Member
    15
    12
    Dec 13, 2010
    Edmond, Ok
    Yep, first mistake was buying a Volvo. My 2013 780 needs a radiator, yes I'm sure, I saw the bubbles at the neck of the top drivers side hose neck. I was hoping someone would tell me the amount of hours they were billed to Replace their Volvo 780 radiator. Thanks.
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
  4. boneebone
    boneebone Road Train Member
    2,298
    2,374
    Mar 13, 2009
    R & R it yourself and you'll save a ton of money.
    KB3MMX and passingthru69 Thank this.
  5. me myself and I
    me myself and I Heavy Load Member
    737
    313
    Oct 5, 2009
    vernon hills,Il
    It's not that big of the job.
  6. Ridgeline
    22,851
    126,482
    IF you want to know, call volvo and ask them, they've got a program that tells you everything like that.
    Most likely 4 hours with help, 6 without.
  7. Brandt
    Brandt Road Train Member
    4,674
    6,478
    Sep 17, 2012
    One thing Volvo does different is the radiator and charged air cooler are bolted together as one piece. When I had mine replaced at Volvo they have to pull both out. So that add to the labor time.
  8. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    Have your rad. pressure tested with it at op. temp, bubbles can be coming from heater air valves or a bad head gasket or pitted cil. liners, but changing the rad. before finding the problem can cost extra cash?
    Jazz1 Thanks this.
  9. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    baha has good advice. I have a '14 Volvo 780 and anything such requiring work on the motor or cooling system I take to my local dealer for a estimate first. I usually have the estimate at the end of the day if the truck goes in first thing in the morning. So far the estimates have been dead on or the actual work is less than the estimate. Let Volvo examine and diagnose the problem as it may not be your radiator, but some other component about to fail.
  10. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    You can fix that exact leak!
    Drain coolant down, clean well with brake parts cleaner then rough with sandpaper.
    Clean again with brake parts cleaner and allow to dry.
    Apply plastic epoxy liberally and allow to harden....
    My friend just fixed this exact same problem...
    radarmonkey Thanks this.
  11. radarmonkey
    15
    12
    Dec 13, 2010
    Edmond, Ok
    12 hours?
    Jazz1 Thanks this.
