Espar maintenance
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dna Mach, Jan 3, 2022.
  1. Dna Mach
    Dna Mach Road Train Member
    3,252
    2,962
    Aug 8, 2008
    Texas
    I’m about to buy a new glow plug, screen, and fuel filter for my Espar bunk heater. After watching the videos and seeing exactly how the process is done, I got to thinking, can these parts be cleaned with any success?
    Seeing prices for the plug and removal socket from $54 bucks to $160. I’m guessing the cheaper one is an aftermarket.
    My issues are excessive smoking when starting and sometimes the heater cutting off when I back off the temp. Although it seems the Power Service I treated my tanks with last week in Colorado seems to have remedied most of these two issues. Also seems like blowing the espar at full blast for a few minutes upon initial start up allows me to adjust the temp lower throughout the night. My company absolutely will not work on these things unless it’s crapped out completely and I was amazed at how simple they are to work on after watching a few videos on servicing them.
    Anybody ever cleaned these parts instead of replaced them?
    D.Tibbitt Thanks this.
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Cleaning doesn't work for long time. In short time heater will start smoking again. Don't forget to order the new gaskets. Old gaskets will fall apart during disassembly.
    bzinger and Dna Mach Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    If it runs, disconnect the fuel line at the tank. Run a gallon of clean Kerosene thru the heater once a year. More if it's never been done before. Usually eliminates the smoking studder on start up without even taking it apart.
  5. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    That socket you can make
    it’s just a deep socket with a grove or slot cut on the sides for maybe a wire to pass??
    Don’t remember if I made my own or just bought one but it’s a tool nonetheless that you’ll use more than once
    blairandgretchen and Dna Mach Thank this.
  6. Dna Mach
    3,252
    2,962
    Aug 8, 2008
    Texas
    Exactly! It’s $12 bucks by itself (included with the plug) so figured I’d just buy one since it will be reused more than likely. There’s a hole in that slot that likes to get build up so I’m thinking in the future I’ll see if it’s blocked up with carbon before buying new parts.
    Thanks, yes I remember in one of the videos he had mentioned that he’d never seen one come out in one piece.
    Snailexpress Thanks this.
  7. JonJon78
    JonJon78 Road Train Member
    7,041
    37,573
    Jul 1, 2018
    I'm actually having problems with mine right now. It will turn on and blow cold air, then shut off and say "no flame detected"
    Just had it installed last year, haven't even used it much...
  8. Dna Mach
    3,252
    2,962
    Aug 8, 2008
    Texas
    If you look at the sticker on the side of it you’ll see a model number. Should be a D followed by a 1,2,3,or 4. You can find service videos on all of them. It’s a pretty simple setup. Some people say they need serviced bi-annually. Mines three years old and made it to this point so far.
    Yours sounds like it might just be a bad plug.
    BoxCarKidd and JonJon78 Thank this.
  9. JonJon78
    7,041
    37,573
    Jul 1, 2018
    Ya, mines D2. Ive watched the videos but haven't been able to find a clear answer on my issue.
    I did remove the glow pin plug yesterday and the tip didn't really have any soot at all on it. Didn't remove the screen but from what I could visually see it looked good/not clogged. I did buy the glow pin tool.and extra screen last year.
    Maybe I'll bite the bullet and order a new glow pin and see if that resolves my issue. I believe they are like $150... I suppose if that doesn't solve the problem, I'll have a spare and will have to try to replace another part...
    LoneRanger and D.Tibbitt Thank this.
  10. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    ...same with my webasto in my kw... hopefully i will get my hands soon on it after i am done driving cascadia :)
  11. JonJon78
    7,041
    37,573
    Jul 1, 2018
    What happened to your KW?
