So my bunk heater stopped working completely, the fuel pump won’t click, the blower fan won’t run. I can’t get any codes since it’s hooked up to my tripac evolution which has no display, I don’t know where to even start, any help would be appreciated
Espar D2 Won’t come on, fuses are all good, what can it be?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Buckeyes614, Dec 28, 2021.
I’d look in the control box under the bunk for a blown fuse since it’s completely dead.
@reeferwrenchercuzzin it, reeferwrencher and Buckeyes614 Thank this. -
Buckeyes614 Thanks this.
You should have a usb cable out of control box download tri pac evolution program
Plug it in and see what codes if any.
Also did you check fuse in battery box?.
Is controller completely dead?.Buckeyes614 Thanks this. -
reeferwrencher Thanks this.
Are you getting power to the fuel pump?
I have seen bunk heaters with a fuse for the pump. It was generally in the wiring bundle going to the heater.Buckeyes614 Thanks this. -
