Engine swap
Discussion in 'Canadian Truckers Forum' started by 10kw, Apr 9, 2022.
  1. 10kw
    10kw Bobtail Member
    Apr 9, 2022
    Looking for help. Have 2010 Kenworth w900l and I replaced the Cummins engine with a 3406 6nz cat. Insurance refusing to give me actual value of the truck and are saying truck is only worth 40,000 because emissions were deleted and can't be sold at a dealer.
    What are my options??? I don't believe this is correct as emissions were not deleted because the cat engine didn't have emissions.
  3. DaytonTD
    DaytonTD Light Load Member
    161
    183
    Jul 14, 2019
    Edmonton, Alberta
    Get it professionally appraised then submit that
  4. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Problem is the insurance company is going to value by going off chassis year of manufacture. Which means as far as they are concerned everything that is required for that model year both safety and emission related has to be there regardless of an replacement engine swapped in. Once truck hits 25year old it can be considered exempt to some agencies.
  5. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    Unless the truck was originally a glider, then the insurance company is correct.
    You put a different emission tier engine in the truck. It would have had to be the same as a 2010 or newer.
  6. classicxl
    classicxl Medium Load Member
    534
    837
    Dec 16, 2006
    Trucks built in the 2and half of 2007 started to have emissions equipment added ,Like a DPF and egr ,Unless your 2010 truck was a Gilder then it had emissions from the factory .By you putting in the older cat engine technically makes it illegal according to the government .I know ontario is making the emissions test even harder on heavy trucks you may run into other issues then just insurance depending on where you live
  7. AModelCat
    154,242
    Technically you did remove the emissions equipment. Doesn't matter that the Cat is a pre-emission engine, what matters is the fact it left the factory with an emissions-equipped engine and I'm 99.999999% sure that truck is not a glider. Almost nobody would put an emissions engine in a glider.
  8. Florescent-android92
    Florescent-android92 Light Load Member
    92
    160
    Nov 21, 2021
    Lower payments then, just don't wreck
  9. Elroythekid
    Elroythekid Road Train Member
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    How do they know you swapped it?
