Engine Oil Change, 06 International 8600, Cummins 11 L
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fritzcoinc, Jun 28, 2016.
  1. Fritzcoinc
    Fritzcoinc Bobtail Member
    21
    Apr 27, 2016
    Hello again from the Oil Patch.
    Anything special we need to know to do an oil change on our 06 Int. 8600 Cummins 11L?
    We usually use Shell Rottela oil and Baldwin filters. We are in the 90's outside temp wise this time of year and this is a city truck. What weight oil is recommended for city driving/use.
    How much oil does it take?
    One thing I see is a filter by the turbo. Is this for the oil feed to the turbo?
    What about crankcase ventilation? Any filters or PCV type valves?
    Anything special about start up after the oil change?
    Should you prime the system, if so how, before start up?
    Is there a " Engine Service" light reset procedure?
    Our truck has 495K miles on it's clock.
    Thanks in advance for any help/wisdom.
  3. bavarian
    bavarian Heavy Load Member
    727
    781
    Feb 13, 2014
    Winnipeg
    With so many questions, are you sure you want to do it yourself.
    -For the oil, use what the manual recommends. In 06, most of the maufacturer used 15W40.
    -Pre-fill filters before installation as long as they are installed upright. Tighten to specs. Avoid tools, which could cause deformation of filter and damage it.
    -The fuel system might need extra priming. Refer to owners manual for procedure.
    -The small filter on the turbo side might be a coolant filter. The turbo gets its oil straight from the engine without extra external filtration. Follow the lines to where they're hooked up to figure out what's in there. If necessary lossen a clamp or fitting to see the fluid while engine is shut down.
    Fill up oil through the fill cap and not through the dip stick. Fill to max and start engine till it builds up oil pressure. Have it running for a few minutes. Shut down and check for leaks. When installing the oilfilter, make sure the flange AND your hands are clean. Makes it easier to check for leaks when residue is cleaned before installation.
    Let the oil settle now for about 20 minutes. It's a good time to change the fuelfilter at this point or do the grease job. When done check oil level and top up to max. DON'T top up oil to max immediately after initial start and shut down. Too much oil is in the head. Topping up at this point makes you overfill the engine.
    Fritzcoinc Thanks this.
  4. Fritzcoinc
    21
    Apr 27, 2016
    I would expect a response like " you are wise to ask questions before jumping in" but that's just me.
    Thanks for the information. We purchased the truck used and don't have any documentation. I'll look on line for an owners manual.
    Thanks again.
  5. o/otony
    o/otony Light Load Member
    190
    49
    Dec 25, 2012
    i have an 05 8600 wit the ism, thats the engine you have it takes 10.8 gallons of oil and yes the filter by the turbo is a coolant filter.
  6. Fritzcoinc
    21
    Apr 27, 2016
    Thanks!!
    What is the fuel re prime procedure after filter change? I cant find an owners manual for our truck.
  7. o/otony
    190
    49
    Dec 25, 2012
    i just fill the filter with fuel screw it back on and vrrooommmm of she go's.
  8. Garzaci
    Garzaci Light Load Member
    90
    71
    Dec 27, 2013
    Generally you just have to fill the fuel filter with diesel and your good. Every now and then you might have to pump the little manual priming pump if you lose your prime. Never had it happen to me but was told you could have to pump that thing a couple hundred times.
  9. Garzaci
    90
    71
    Dec 27, 2013
    So post something useful then dimwit.
    christian cothran Thanks this.
  10. Fritzcoinc
    21
    Apr 27, 2016
    Been there, done that, got the tee shirt working on an old Mack Cab Over. It took a long time to pump it up!
    Reminds me of an old joke:
    I pumped, She pumped, then we worked on the truck.
    Thanks
