Engine mount replacement cost?
Discussion in 'Volvo Forum' started by Helowrenchturn2, Mar 11, 2015.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    2007 780 ved12....anyone have this done lately??
    KB3MMX and mp4694330 Thank this.
  3. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    Can I ask why You want replace?
    Own myself '01 610 with D12.
    Thanks.
  4. Helowrenchturn2
    484
    140
    Apr 23, 2013
    because they are bad and are causing a floor thump and vibration
  5. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    you can pop your hood. and watch the engine as you slowly let the clutch out. but not enough to kill the engine out and only do it briefly. see if the engine jumps.
    some trucks will actually break the fan shrouds and possibly cut the radiator and fan if the engine moves too much.
    KB3MMX and Helowrenchturn2 Thank this.
  6. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Already did that. Also, I crawled under and looked at them with a flashlight. You can see the rubber is cracked, split and has shrunk. I know they are bad, just curious about replacement cost. Volvo quoted $2600 just for labor. I Can get all 3 mounts for about $300 but don't know if it's a job I want to attempt
  7. snowwy
    20,525
    13,261
    Jul 6, 2009
    Your going to have to lift the engine some to get the mounts in place. They probably won't slide out and in and line right up.
    That should answer your question.
  8. ROADONE
    ROADONE Bobtail Member
    16
    5
    Mar 16, 2015
    Hi, I have a vnl780 2005 and did the mounts last month at a smaller shop and saved a bunch. Dealer charges to what I've read over 2k$. Which is ridiculous if true. It's a tricky job just have to be careful, my mechanic lifted up engine by supporting evenly using the oil pan. Sounds crazy but he says he has done it like that for years. I was shocked myself. Lifted it up enough to swap. That's probably not the right way, I wonder how dealer does it?? 200$ labor plus mount I'll take that. Hope this helps
  9. Helowrenchturn2
    484
    140
    Apr 23, 2013
    That helps a lot! Where is the shop located??
  10. ROADONE
    16
    5
    Mar 16, 2015
    No prob. It's a suburb of south Chicago here's the address name is MMCH truck repair
    6605 KITTY AVE
    Chicago Ridge IL‎ us, 60415
    United States
    1 (708) 822-4947
    Helowrenchturn2 Thanks this.
  11. ROADONE
    16
    5
    Mar 16, 2015
    Smiley is the number eight, lol
