Engine fan won't shut of
Discussion in 'Peterbilt Forum' started by Harley Tramp, Sep 2, 2013.
  1. Harley Tramp
    Harley Tramp Bobtail Member
    13
    Aug 28, 2013
    I have a 2006 Pete with Cat C15. Engine fan won't shut off. Solonoid is good. When it is jumped fan shuts off. Checked wires as much as i could. Manuel switch inside works fine. Help..:biggrin_25510:
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    when that happened to me in my KW 700 was a wire connector in the harness going thru the firewall
    $139 at the dealer
  4. Fatone
    Fatone Bobtail Member
    15
    Jul 11, 2013
    Possibly bad A/C hi pressure fan switch(sensor) on condenser
  5. Tobytob
    Tobytob Light Load Member
    129
    154
    Aug 17, 2013
    Possible fan clutch as well, unplug ac high pressure switch if it shuts off then theirs your problem. If not I bet the clutch is bad.
  6. hoss699
    hoss699 Bobtail Member
    19
    9
    Oct 5, 2013
    Midland. Tx
    I just saw your question. I see that it's been here quite some time. I have a 96 pete with an e model cat. I had the same problem with the fan staying on. I replaced the fan sensor and it fixed the problem. It is located on the front right of the engine under the a/c and next to the alternator. I had to have a 1-1/16th inch deep socket and I had to grind a slot up one side of it so the wire loom had room. Hope this helps.
    baha Thanks this.
  7. Harley Tramp
    13
    Aug 28, 2013
    Thanks, i will give that a try
