engine fan switch
Discussion in 'Volvo Forum' started by chris childs, May 11, 2013.
  1. chris childs
    chris childs Bobtail Member
    Hi everyone this is my first post on here.
    I have a 780 , D16 and would like to get a fan switch installed to have the ability to have it pre running in warmer weather before hitting BC's mountains.
    Reason being it was 33C here last week and pulling a super B at full weight, and having the a/c running beforehand, it got mighty warm on the first 10mile gradient LOL. Not funny actually a little worrying!
    Dealer told me there should be a plug in the harness as this is an option on the standard, and I did have a switch position open when I bought the truck but got them to put a blank in it. Thinking the last company might have taken the switch out for their new truck! Any ideas greatly appreciated.
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    When I ordered mine Volvo stated it is not offered as an option but I understand you can add one, just have to make sure to wire it correctly. Check further into this forum there's plenty of threads on it.
  4. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    you should be able to pull the dash down and check there will be a hand full of switch wires there just read them and see what one says fan overide put a switch in it
  5. adreanis
    adreanis Bobtail Member
    19
    Apr 7, 2013
    CHICAGO, IL
    How do you pull out the right side 10 swich panel? Does it have screws or clamps on the inside?
  6. jameslawton
    257
    65
    May 1, 2013
    Tulsa OK
    Should have screws the plastic should pop off and screws under it
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I found no auxilary inputrs for fan switch, so the only way - use A/C clutch input to actuate fan
  8. Mlaz Bogdanci
    Mlaz Bogdanci Light Load Member
    58
    11
    Feb 5, 2012
    Santa Monica , CA
    My 2 cents don't do it.Its a computer controlled engine if you needed it it would have been there already.Slow down and downshift turn the ac off for a few minutes on the hill.Thats just my opinion
  9. Yellow Venom
    Yellow Venom Bobtail Member
    25
    Dec 15, 2012
    Edmonton,Alberta
    I agree 100% with putting a Manual fan switch in, my 770 had the plug in it, all I did was get it turned on at Volvo in the computer and plugged in the switch it was at the left side of the steering colomn, I have an '07 780 and there is NO plug in the harness to plug a switch into, I'm taking mine to Volvo they said they can wire it in in an hr.
    I think it's not the smartess thing by not having a manual switch, up here in Canada we pull very heavy loads (125k lbs super B loads) and we for sure need to cool down before and during the pulls in the mountains here.
  10. d281833
    881
    919
    May 15, 2012
    I didn't have one on my '06, don't have one on this '12 and they seem to do what they're supposed to do. Uh Canada's not the only place that has a hill or two. Just sayin'.
  11. Yellow Venom
    25
    Dec 15, 2012
    Edmonton,Alberta
    Lol I'm not saying Canada is the only place with hills, I didn't mean it like that if it came across like that, but we pull 125k lbs loads plus up here all the time, were not that lucky to only have 80k lbs loads being a common thing up here, that's why out roads are so rough and beaten up up here!
    I was more less referring to the heavy loads in the hills, I live a couple hrs east of the Rocky Mountains in Alberta.
