Engine coughs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Krysik, Sep 21, 2017.
  1. Krysik
    Krysik Bobtail Member
    7
    Hi. 2007 International 9400i. With Cummins isx. Engine has egr but no after treatment.
    It coughs once or twice at startup and shoots a cloud of smoke through exhaust. Otherwise works fine.....idle or driving. No codes. Help.....
  3. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Add about a quart of Robitussin to each tank, and apply a full jar of Vicks to the air filter. :p
    magoo68 and xsetra Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    "Coughing" is usually associated with exhaust restriction and air flow actually stalling through the engine and reversing out the air cleaner to produce that sound. Only the turbo actuator has the ability to change and restrict exhaust flow like this on a temporary or certain conditional situations. If the exhaust after the engine was restricted, this is more permanent and would cause performance issues all the time. Make sure all your sensors are clean and your turbo actuator is working normally.
    xsetra Thanks this.
  5. Krysik
    7
    Thank you. Is that actuator controlled by air? If so, is it possible that I have an air leak there causing it to malfunction? My air compressor seems to kick in every 3 minutes and I cant locate the leak.........
  6. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yes, it is air actuated and only uses air when the engine is actually running, so it can be hard to find a leak. You can actuate it with the key on with Insite to check for any leaks and proper operation.
  7. Krysik
    7
    Thank you very much. I appreciate your time.
  8. owner
    owner Bobtail Member
    11
    I have an older ISX with an air actuator.
    There is a filter on the drivers side to filter the air to the actuator. I had mine changed and it was plugged up, my boost went up significantly after.
    Not saying this is the problem but you never know, I know the shop didn't even know.
    It is a very short filter.
  9. Krysik
    7
    Hi. I didnt know it. Ill try to find it. Thank you. Can u give me a better location?
  10. owner
    11
    It is just under the compressor. It is a small, short filter fairly easy to see. You may think it is being changed when the truck is being serviced. Follow the air line from the actuator backwards.
  11. Krysik
    7
    Thank you. I will let you know.
