Engine code 21 on 3406e
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bull hauler, Oct 25, 2013.
  1. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Sensor supply voltage fault, anyone know what sensor this is?
  3. wore out
    wore out Numbered Classic
    15,340
    185,255
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Timing sensor supply voltage, sounds silly but clean and check all batt and alternator connections. Then look for a bad or chaffed spot in harness. Sense it is supply voltage related a sensor most likely won't help it.
    bull hauler Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    This is a problem in the 5 volt sensor supply. It is not a specific sensor, all 3 wire sensors use it. Most likely a wiring problem, but a shorted sensor could cause it. That code means that the 5 volt sensor supply voltage is too high or too low. Without getting it hooked up to Cat ET, all you can really do it check all the connections and wiring.
  5. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    check the wire harness as it makes the bend over the left front corner of the valve cover and front of valve cover its a favorite wear spot
