Engine Brake Weak
Discussion in 'Freightliner Forum' started by Buffalo Jeff, Jul 29, 2022.
  1. Buffalo Jeff
    Buffalo Jeff Bobtail Member
    7
    5
    Jul 29, 2022
    Hi All,
    I have a new 2023 Cascadia, DD15 @ 505/1750, DT12 Transmission. Having an issue with the engine brake. Low is non existent, Mid is ok, High has no change from Mid. In both Mid and High settings at 1800 rpm only getting 12 psi of boost and very little braking feel. Been to the dealership and according to them everything is good. I’m only at 6000 miles on the truck but running in the mountains it just wants to run away on every hill. Anyone got any suggestions on what might fix the issue?
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    As I understand the Gen 5 DD15 activates the rear solenoid for low engine braking, both front and rear solenoids for medium braking and for high braking both front and rear solenoids are activated along with EGR . Each solenoid controls 3 cylinders. It sounds like you are not getting any contribution from the rear cylinders. Can you post the last six of your VIN and did you get a description of what was done at dealership to make the determination. Seeing technician notes would be interesting, if done without naming location. I am seeing about 28 steps in troubleshooting for poor engine brake performance.
  4. Buffalo Jeff
    7
    5
    Jul 29, 2022
    Hi. VIN ends NZ0330. It’s a company truck so my notes from the dealership are limited, they basically tested it on the computer and took it for a drive around the yard and said it’s working.
  5. SWM_TECH
    139
    145
    Apr 15, 2018
    Does your company have more than one of these 2023 Cascadia's with the same spec's? It would be nice to compare your truck with another on the same grade and load. I sure other driver's in your company come down same hills. The Gen5 DD15 has a 21 to 1 compression ratio which is higher that earlier versions, Which in my thinking should give slightly better engine braking. If you got engine faults related trouble shoot them first otherwise going through the diagnostic steps for poor engine brake performance is what I would recommend. I am certain that Detroit Diesel will be able give some guidance to dealer if they have need help solving problem. Here's the diagnostic steps for poor engine brake performance.
  6. Buffalo Jeff
    7
    5
    Jul 29, 2022
    Thanks for the help, I’ve talked to a couple other drivers who are noticing the same thing with theirs as well (both the DD13 and DD15 new units).
  7. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    you need to take off exhaust rocker arm and look for stuck actuator pistons...
    happens very often with all dd15 models.
  8. Antinomian
    Antinomian Road Train Member
    2,078
    3,243
    Feb 17, 2013
    I had that problem myself, but he said his is a brand new engine. I would be shocked (and pretty mad) if I had that problem on a new engine.
    BTW you don't actually have to take the rocker assembly off just to check the pins. You should be able to use an air chuck with a rubber tip in the solenoid orifice. The pins will pop out from air pressure too. The diagnostic procedure calls for 50 PSI.
  9. Buffalo Jeff
    7
    5
    Jul 29, 2022
    Well, it went back to the dealership this morning. They changed the Jake Heads and EGR valve. Test it out tonight and see how it goes.
  10. LoneRanger
    LoneRanger Road Train Member
    3,663
    9,447
    Jun 3, 2018
  11. Buffalo Jeff
    7
    5
    Jul 29, 2022
    And still not working, decent in 2nd but still no step up to 3rd stage. And 3rd stage pulls less boost then 2nd
