Energizer Group 31 AGM Battery
Discussion in 'Ask An Owner Operator' started by TheEnglishMan, Aug 18, 2013.
  1. TheEnglishMan
    TheEnglishMan Light Load Member
    231
    60
    Oct 3, 2012
    Anyone using them? Looking for feedback. $179 from Sam's Club.
  3. Horse Whisperer
    Horse Whisperer Light Load Member
    199
    180
    Jan 6, 2013
    The problem with Deep Cycle Batteries is that they aren't designed (and thus don't hold up very well), as cranking batteries... I've used AGM's in sailing applications (long duration - offshore stuff), and they work very well for "hotel" loads.... the boats always had a separate bank of batteries for the motor... I've been using the 31 HD from Tractor Supply, about $100 each, 900 CCA... work great for my 2003 Columbia, S60.
  4. TheEnglishMan
    231
    60
    Oct 3, 2012
    Need hotel load as well as cranking capabilities. Have 4 batteries. Optima is the obvious but looking at slightly cheaper alternatives.
  5. Horse Whisperer
    199
    180
    Jan 6, 2013
    Yeah... the regular cranking batteries will carry the hotel loads, O.K., just not for as long... the safest option, depending on your application(s), may be to install a cold-start capacitor system, 2 cranking batteries on an isolated charging circuit, and 2 AGM, also on an isolated charging circuit... Expensive as all get out, but will definitely protect ALL of your systems: charging, cranking, and hotel load requirements.
    Hope that's clear as mud! LOL!
  6. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    a cheap generator or auxiliary power unit will take care of all your hotel needs. leave those batteries to do what they were designed for, crank the engine.
