Endorsements required to drive a double bottom dump truck?
Discussion in 'Trucking Industry Regulations' started by David_abl, May 27, 2014.
  1. David_abl
    David_abl Bobtail Member
    8
    Are there any other endorsements required aside from the double/triple endorsement to haul dirt, asphalt, and gravel in a double bottom dump truck?
  3. Singh181
    Singh181 Light Load Member
    57
    43
    Jan 26, 2014
    San Jose, Ca
    Have to get a doubles endorsements then ur set.
    David_abl Thanks this.
  4. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Make sure it reads, double bottom gravel. LOL
  5. baseballcoach
    baseballcoach Light Load Member
    105
    72
    Mar 23, 2011
    Illinois
    Some asphalts need hazmat. Something to do with flashpoint and weight of product. I am sure someone here has the answer
  6. Singh181
    57
    43
    Jan 26, 2014
    San Jose, Ca
    Think thats for the liquid asphalt only that goes in the tankers maybe
    baseballcoach and David_abl Thank this.
  7. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    Double trailers need doubles endorsement. Asphalt/sand/gravel isn't haz.
  8. keitht
    keitht Light Load Member
    115
    224
    Feb 23, 2012
    USA
    When does a driver need a double trailer endorsement on their CDL?
    Question 2:Are drivers of double and triple saddle mount combinations required to have the double/triple trailers endorsement on their CDLs?
    Guidance: Yes, if the following conditions apply:
    —There is more than one point of articulation in the combination;
    —The Gross Combination Weight Rating (GCWR) is 26,001 or more pounds; and
    —The combined Gross Vehicle Weight Rating (GVWR) of the vehicle(s) being towed is in excess of 10,000 pounds.
    You need a hazmat endorsement only when you are hauling a placardable load. Hazmat that does not require placarding does not require an endorsement. Asphalt is not haz mat.
