Im trying to start my own business, I’m out here in Phoenix,AZ at the moment at i work for a concrete company driving a ready mix truck pays good but I want to start my own stuff get my own truck and trailer. Out here there is a lot of end dumps & flatbeds. End dumps are hauling a lot of demolition, aggregate, etc. The flatbeds are hauling a lot of varieties of stuff. I don’t mind either or But the problem that I’m facing is I don’t know where to get started or where to get contracts for these type of stuff. Any advice for it will be very appreciative thank you !
End dumps or flatbed
Discussion in 'Ask An Owner Operator' started by Gorillathetrucker, Feb 7, 2024.
Page 1 of 3
Side dumps are much safer then end dumps. They don't have the risk of tipping over.
Gorillathetrucker Thanks this. -
I think some sort of long haul dump work might be doable, but today, you simply can't go wrong with a flatbed. I'd say, at least 75% of all the trucks I see in Colorado, are flatbed. I did a lot of dump work, local stuff, never seemed to pay very well, and so many factors, like weather, equipment. Flatbed opens up a whole lot of options, stuff not many can haul. Construction is huge and flatbed services them all.
Depending on what Side of the country you're in.
Side dumps can haul up to 40+ tons with the axles. There are 7 axles Side dumps. 2 axles can only haul 18 tons.
End dumps require 3 axles to haul 20 tons. They don't have the bridge to weigh 80k. Without that 3rd axle.
If you're dumping in wind. Have a load that won't come off the front. On uneven ground that can make the trailer tilt.
They go over.
Very few end dumps have 3 axles. Or more.
Very few side dumps have 3 axles or less.
Side dumps haul more. Not end dumps.
End dumps are more dangerous then Side dumps.
I don't know where your seeing otherwise. I've seen end dumps. Have yet to see side dumps.Last edited: Feb 8, 2024
hiredgun Thanks this.
I've pulled both ends and sides.
There aren't alot of ends in my area. Sides have taken over in the past 22 years. -
You could not give me another full frame trailer, I liked my 1/4 frame, but frameless is still the way to go IMO
honestly, flatbeds are starting to get cheap enough, buy both, then of one slows down you have plan B, also, some companies may have occasional use for a flat on top of the dump, like delivering concrete blocks to customers etcGorillathetrucker and 201 Thank this.
Page 1 of 3
