End dump tailgate wiring
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by BubbaCox, Jun 20, 2022.
  1. BubbaCox
    BubbaCox Bobtail Member
    23
    10
    Jul 2, 2017
    Hello I just bought a 2021 load king half round. Coming from a belly dump. I can’t figure out how to get the tailgate working. Belly used a round 4-way as does the new end dump. The belly only used 2 of the 4 wires and the back side of the round 4-way on the end dump has all 4 wires connected. I’ve done tons of research and can’t find a good lead. Even called load king and no call backs. Thank you.
  3. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    813
    1,584
    Dec 15, 2021
    It might have extra wires for the tailgate latch,I'm not sure ,just guessing.
    Probably separate circuts for gate lift and gate latches.No gate latch on any belly dumps I have ran.
  4. RockinChair
    RockinChair Road Train Member
    4,919
    12,258
    Feb 19, 2012
    CC, TX
    Have you looked at the air valves to see what color wires are connected to them?
  5. BubbaCox
    23
    10
    Jul 2, 2017
    No sir I haven’t started tearing panels off just yet. I got the latches to open but no luck on the gate.
  6. RockinChair
    4,919
    12,258
    Feb 19, 2012
    CC, TX
    Well if you got the latches working then you have already found the ground. Try putting power to each of the remaining pins and see what each one does.
  7. BubbaCox
    23
    10
    Jul 2, 2017
    Well I guess I had it figured out already. Latches and gate work off same switch. According to load king themselves. Flip the switch and latches open. Go back and push on gate it tries to open. It will sometimes open all the way up but is so weak I can hold it shut with my hands. I’m guessing an extremely weak air supply. Trailer brakes released in truck and 125 psi. Now where to start with air lines.
  8. North Pole Nightmare
    813
    1,584
    Dec 15, 2021
    May just need to cycle it a few times.
  9. BubbaCox
    23
    10
    Jul 2, 2017
    I probably worked it up and down 10 times. Didn’t seem to want to get any better with each cycle.
  10. North Pole Nightmare
    813
    1,584
    Dec 15, 2021
    We had an old Clements years ago,it was always slow to open.
  11. BubbaCox
    23
    10
    Jul 2, 2017
    This won’t even try to open unless I push hard on the gate. And it’s basically brand new
