Emergency stopping (question)
Discussion in 'Questions From New Drivers' started by Acdeep, Jul 9, 2019.
  1. Acdeep
    Acdeep Bobtail Member
    4
    Jul 9, 2019
    I have a question regarding having to stop at full speed, loaded, in a short distance. Let's say I come around a bend on an interstate and the traffic around the corner is completely stopped and heavy in all lanes. What if the service brake and clutch wont be enough to stop? Would pulling the trailer emergency brake and leaving the tractor break disengaged while applying the service brake help stop the truck better then slowing it down and causing a huge accident?
    D.Tibbitt Thanks this.
  3. Acdeep
    4
    Jul 9, 2019
    Im asking because earlier I nearly avoided a terrible accident. I was in 10th. No time to downshift and had to firmly apply the brakes and hold my clutch in. I barely stopped in time. What if I would've had a heavy load n such. My load was only about 26k. I'm just trying to think what to do if I had been heavier or less stopping distance?
    Lepton1, CousinVinny and D.Tibbitt Thank this.
  4. wore out
    wore out Numbered Classic
    18,255
    231,386
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The park brakes and service break are the same shoe.
    Pulling the trailer brakes will stop the trailer service brake from getting air, which means they rely on spring pressure only very bad idea
  5. D.Tibbitt
    160,852
    Hit the shoulder . put it in the ditch if thats ur only choice. Do not whatever u do hit stopped traffic , because if u kill somebody there is not a good enough lawyer out there to get u out of it.. But really in all honesty being a good driver is about anticipation . a good driver that sees a blind corner he is fully expecting there to be stopped traffic and should already have the break covered with his foot and letting gravity coast his truck and naturally decresing his speed. Dont be one of those guys hauling ### in the left lane trying to pass a truck in the right lane while going around a right hand curve and never backing off. U cant see anything from that spot , one these days some these guys is gonna kill somebody. Just be aware , its the same thing with stoplights . the best way to be able to break for it is if u come up on a green light thats been green awhile and there is cross traffic sitting there waiting, chances are it will change, u should have ur foot covering the break and when i get close enough i hammer back down. During bad weather im slowing more and my zone for stopping is shorter and im not scared to run thru that split second red light if i have to on ice or heavy rain, or even depends if im hauling certain loads that like to move. Flatbed has taught me to be a good driver or atleast try to think about what im doing and how the freight will react to it.. But really Anticipation is the key to staying out of trouble
    SoCalRed, Lepton1, TripleSix and 9 others Thank this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,808
    9,871
    Oct 5, 2012
    Earth
    Just the same as not overdriving your headlights you want to be careful around blind corners. The heavier you are the better your traction typically so that's not a huge concern.
  7. AModelCat
    166,502
    You get the most traction when the tires are at the verge of locking up. If you pull trailer park brakes on, you risk locking up all the trailer tires. Bad because of several reasons:
    •You have much less traction when tires are skidding, which increases stopping distance.
    •Your ABS system, which prevents wheel lockup, works on the service brakes. It will have ZERO effectiveness if you set the trailer park brakes.
    • If the trailer tires lock, you risk major loss of control.
    Reader's Digest version: Very bad idea.
    Lepton1, flood, MartinFromBC and 6 others Thank this.
  8. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    You know what, you probably weren't anticipating what was around a turn from the sounds of it and I'm glad nothing bad happened. Good on ya for coming on here and describing your problem and wanting to learn how to get better....not many people do that unfortunately.
  9. Dave_in_AZ
    447,916
    1) Expect the unexpected.
    2) Avoid the collision.
    3) Aim high in steering.
    1 & 3 - Just like these guys that fly down hills. I've often wondered where they get those guarantees nothing is blocking the road around the next bend.
  10. SuperRookie
    SuperRookie Light Load Member
    51
    64
    Apr 11, 2012
    Eton, GA
    Everyone pretty well summed up what I would say. Bad idea. Use the brake pedal. Abs and all that helps ya control now days.
    I will say this, if u dont have a CB get one. If u have one and u keep it off, stop. Lol I cant tell a how many times I have been coming up to a slow down or stopped traffic and been warned on the cb. While every time I have seen it before they hollar on the radio, it's still been nice to know. Its annoying sometimes, but still pretty useful tool deom time to time. Just my $0.02 :) be safe out there.
    Lepton1, D.Tibbitt, RustyBolt and 4 others Thank this.
  11. Doublewiggle32
    Doublewiggle32 Light Load Member
    82
    116
    Jan 3, 2016
    I know of someone who did this in a bad snow/ice storm... didn't end well a few years ago. It started a big pile up, like 30 vehicles.
    Terrible idea because unlike using the brakes once you pull the parking brakes you won't be able to release them.
    So if it starts to jackknife after setting the brakes you're screwed. If you just use the service brakes and start to skid you release the brakes a bit, and your able to gain control to avoid the traffic by stopping in time, or using the shoulder or ditch if needed.
