Electrical problems with Kenworth w900
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kevlar, Jan 12, 2014.
  1. kevlar
    kevlar Bobtail Member
    7
    Feb 19, 2012
    Clanwilliam,MB
    Hi, I cant figure out my trucks wiring. My fog lights aren't working so I thought I would start following the power right from the switch on the dash. As soon as I connected the test light to the power at the switch, all the dash lights came on and the marker lights also came on. Have I got a short to ground or is it something else?:biggrin_2552:
  3. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    If your switch is a factory fog light switch then it works off the grd. not power.Check your fuse & relay in your fuse box to make sure they are good.
  4. poppahouzr
    poppahouzr Bobtail Member
    Tamaqua,Pa.
    Most kw`s are grounded at the switch. start with fuses and relays.
  5. Dgeorge
    Dgeorge Bobtail Member
    I have a 2007 w900 all my gauges with the exception of tach and speedometer keep loosing power even the back lighting turns off. if I turn off the ignition and turn it back on they all reset like normal stay on for a short period of time and then shut down
    can anyone help me out with this????
  6. Rolling18
    Rolling18 Light Load Member
    170
    34
    Dec 11, 2008
    Portland, OR
    Hello add me to this problem,, Similar to others, I have NO gauges/ backlights except the backlighting of the spedo/ tach. ( 07 W900 Dump) sometimes they will function untill I shut'er down for awhile (not fuse)
  7. Mitchelltransport
    Mitchelltransport Bobtail Member
    Hey. Did you ever fix this problem? I currently have this exact issue.
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Those newer trucks have a body control module in them the same as a car. That’s why wiring anything into them like accessory lights or added switches is a headache. They didn’t do anyone any favours when they went all NASA with the electrical systems. I had an ‘07 W900L for a while and got rid of it for that very reason. No end of lighting and switch function problems.
  9. Mitchelltransport
    I changed the module in the dash because the lights weren’t working properly and that fixed that problem. Are you talking about the module that is located behind the cup holders?
  10. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    There’s one there behind the console, and another one was down on the frame behind the battery box. The one in the console is for instrumentation function and some of the interior lighting. The rest of the lighting and a bunch of other stuff is the one on the frame.
