electrical problem with the ecm detriot series 60
Discussion in 'Trucks [ Eighteen Wheelers ]' started by racer24, Feb 26, 2014.
  1. racer24
    racer24 Bobtail Member
    8
    Feb 26, 2014
    hi,I have a problem with my temp gauge,when the wires or it could be where the harness plugs into my ecm,when it gets wett,say its raining,or even when ive had my engine washed,my temp gauge will go to 250 and the warning lights will come,then the gauge will go back the other way say to 130,and the warning lights will go out,my engine is not hot tho,I thot about unplugging the plugs at the ecm and cleaning the connection,anyone ever have had this problem,and if so anyone got any advice on how I should try to fix this problem,i would like to fix it myself if I can,im an o/o and hate to pay a shop 100 an hr,if theres away that I can get to the bottom of this,any replies would be appreciated,thanks rick
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Check the coolant sensor connection. It should be towards the back of the head right below the valve cover on the passenger side. Also check your ground straps on the engine. If they are corroded you could get erratic readings.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    What ConCruiser said. In addition, if this is a DDEC V or newer, it is common for the plastic covers on the ECM connections to chaff wires. Take the plastic covers off and look for wires rubbed through. On ours we ground the covers out a bit so they don't pinch the wires so tight.
  5. racer24
    8
    Feb 26, 2014
    thanks for replying,its not the temp sensor,my truck is 2002 Detroit,grape ape your reply is in line with my issue,but would those ecm connectors when they get wet,cause this to happen,thanks rick
  6. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Yes, it could happen when it gets wet. I haven't seen one break a wire, just rub through the insulation. Bare wires and water don't mix well. If there isn't a problem there, I don't have any other tips other than tracing the wires from the senor to the ECM. This is where software really helps, you can wiggle, spray or do whatever while monitoring the readings looking for fluctuations.
    I had an ISX once that when it got washed, it'd only idle and had TPS codes. I hooked it up and slowly started hosing down the engine, when got by the rear of the valve cover, things started to fluctuate. I broke open the harness loom around the back of the valve cover and found several chaffed wires.
  7. racer24
    8
    Feb 26, 2014
    ok thanks for your reply,i have a good idea where its at,at the fuel island in florida I hosed down the engine just by the ecm,and my gauge started going crazy,so I no its the wires coming out of the ecm,I will pull the wire cover and check today,when I find the problem I will repost,thanks again.rick
  8. Dieselwrangler
    Dieselwrangler Light Load Member
    128
    92
    Oct 16, 2011
    Edmonton, AB
    You deserve everything you get, I hope it burns to the ground next time.
  9. racer24
    8
    Feb 26, 2014
  10. racer24
    8
    Feb 26, 2014
    is that how you usually reply to threads,if I were the administrator id kick you out of here,my heat gauge issue has nothing to do with an electrical fire,stay in Canada where you belong,us us drivers don't want youns here anyways,thanks for the reply
