Electrical Issues
Discussion in 'International Forum' started by BTGA, Jul 23, 2022.
  1. BTGA
    BTGA Bobtail Member
    Hey everyone. I have a 2012 international pro star maxxforce N13 engine. I am at a loss. Truck is deleted the ABS light, check engine, abs trailer light, service light, traction control light and caution triangle is on. Truck recently serviced. Codes are SPN 2011 FMI 9 SPN 1382 FMI 14 SPN 886 FMI 14 SPN 524285 FMI 14 and SPN 2000 FMI 9. Truck runs good. Any help is appreciated.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    ABS problem will cause all those lights. Those codes are all from the body controller. Get the truck scanned to see if the ABS module is even communicating and what codes it is reporting. 2011 code is the body controller not able to communicate with the ABS. 2000 code is datalink failure related.
    QUALITYTRUCK Thanks this.
  4. BTGA
    BTGA Bobtail Member
  5. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Does that program have a datalink sniffer, or the ability to list all the modules it is currently communicating with? Going by your list, you have a datalink problem that is either wiring related, or a corrupt module. A simple test is to reboot the whole truck by disconnecting the batteries for 5 mins and then reconnecting. If communication is restored, you likely have a module that is getting sad.
    2013Maxx, xsetra and AModelCat Thank this.
  6. BTGA
    BTGA Bobtail Member
    Okay thanks Heavyd. We will try that in the morning. One mechanic told us the ecm needed to be reprogrammed and another one told us it was because our Bendix wingman was not connected. I will definitely try disconnecting the battery.
  7. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Wingman being disconnected will cause all that too. Wingman is needed by the engine to be able use cruise control if it was built with adaptive cruise control.
  8. Flaca6533
    Flaca6533 Bobtail Member
    Hi do you get fix. I have the same issue in my 2012 international maxxforce 7 BE change the ABS and the emergency brake is lock and no one can see why. Let me know please
