Electric reefer units
Discussion in 'Ask An Owner Operator' started by Oregonbythesea, Jun 23, 2011.
  1. Oregonbythesea
    Oregonbythesea Bobtail Member
    Portland, Oregon
    Help! We need some information about the fully electric reefers offered at Truck Transport Refrigeration. They are driven by a generator mounted in place of the alternator that provides 220 3 phase electric while the tractor is running and then it can be plugged in. Any info on these units would be appreciated.
  3. Mr. PlumCrazy
    Mr. PlumCrazy Road Train Member
    1,341
    606
    Jul 30, 2009
    Lexington NC
    Wouldnt do me anygood I havn't seen any shipers or recivers with plug ins for trailers and doubt I ever will and you have to have your truck running all the time so wheres the savings. I dont think these fully electric reefers will go to far by time they kill a few sets of battries and a couple alt. putting all that extra idle time. About as good as an electric car good for in town but useless in the long haul
  4. Oregonbythesea
    Portland, Oregon
    I don't think we are talking about the same units. These have a generator system that replaces the alternator on the engine. They are fully electric and yet still supply all the DC required. I have seen two of them but couldn't get to talk to the drivers. As for plugins at stops, I checked with some and they said they were having to put them in or the units can't be run after the truck is parked. Also, along I-5, they are putting in power outlets at rest areas. I just don't want to be left behind if there is a better way than listening to that noisy diesel up there. And, fuel isn't getting any cheaper as far as I am concerned.
  5. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    i hauled banana's off the pier and thats what they use so when the container is on the boat you just plug them in.......when on land they go on a container chassis that has a generator mounted underneath.....they are a good 3-4000 lbs heavier than a standard reefer trailer and unit......also you will use more fuel because the generator must run all the time so the reefer unit can cycle with temperature
  6. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    If you have a specialized use that requires and supports these, then it will work. Otherwise I think it's a waste of effort.
    Just like 112racing said, there is an efficiency loss in the conversion of mechanical power to electrical power. That loss alone makes this more expensive to operate. I doubt it will achieve widespread acceptance.
    Why would others pay costs they can shift to us owner/operators or trucking companies? Check the long history of shifting costs to us.
    NealinNevada Thanks this.
