Electric over air valve.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chad, Feb 4, 2011.
  1. chad
    chad Bobtail Member
    24
    Graham, Texas
    Guys my new dump trailer is set up to open the gate with a push pull air valve on the frame. I want to run a switched wire to a electric valve to open from cab. I need an electric over air that sendsair one way when off then when opens send air to other end ofcylinder to open it. the cylinder for the gate is not spring loaded to close. Any one have a part number or any help on this. I have looked at 100 valves on the net but not sure what I need.
  3. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    It uses air to hold the latches closed, or do springs hold the gate closed and only uses air to open it?
    Doesn't matter it just changes what valves you need. You can do it with one or 2 solenoid valves, or one solenoid valve and a 4 way inversion valve. It's the same as lift axles and can be done a lot of different ways.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    use any 12V ABS valve. There are two coils - holding and dumpng air. Use dimping air coil. ABS valves dumps air from air bags in some seconds.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    when you turnt voltage off valve lets air from levelling valve fill air springs againe, but slower. I usually add two valves for both the sides to lower faster
    when you'll get valve on JY post me its brand and number, try to get Wabco, I will tell you what terminals to use
