Electric fans
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Md420, Jun 11, 2016.
Page 1 of 3
Can't see why not - may need to up rate your alternator.
Quad fans, like 4 10" ?
What was your reasoning for considering it? -
I am a car guy, it was always a way to free up a little hp, and more efficient at cooling and less physical drag on the engine. I just thought it would be a no brainer with the huge ### clutch fans these trucks run.
Fan can use 50 HP , is what I have heard.
Electric fans work well in some applications. I am all for finding ways to reduce the load on an engine when you really need power. Nothing like pulling a hard grade at full load and the fan kicks in and sucking the power away. A few things to consider first. Will the flow be push or draw. Engine mounted fans are draw, they pull the air across the cooling coils. Draw system have some advantage over push systems due to not having to work aginst high static pressures. On a push system, you have to consider the static pressure at the front of the cooling stack, and the flow restiction across the stack. In order to overcome these, it may require fans that are just too big to fit into the space available, or the electrical load is well above what could be considered acceptable. Electric fans need energy, has to come from somewhere. Big alternators can be just as high a load on the engine as the stock clutch fan.
Are you kidding. You'll never get electric fans to flow as much cfm as your oem fan. Just not gonna happen . Not to mention it would be a wiring nightmare with the amp load. You'd need an extra alternator just to run them .
wore out Thanks this. -
The biggest issue with it has already been said, getting the flow. I used to switch to electric fans on my car's as well, but it's a huge difference when looking at just how much air flow you'd need for a semi.
Not saying it can't be done as I've never looked into it, but you'd need a good fan -
Ask skateboard. He may have a picture of a girlfriend of his that had them on her Autocar.
Page 1 of 3
