ELD question - same driver, two trucks
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by 6wheeler, Nov 1, 2016.
  1. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    I have 2 trucks, sometimes during the week I use one and then the other.
    How are ELD going to keep up with that? It will look like I'm off that day whatever truck I'm not driving. LOL.
    Ruthless Thanks this.
  3. Fatmando
    Fatmando Medium Load Member
    381
    446
    May 14, 2012
    Pittsburgh, PA
    You log into your ELD in whatever vehicle you are driving. You put in the vehicle identifiers the same as you would write them on your paper log, which would also go with you in whatever vehicle you are driving. The ELD tracks logs associated with you, as a driver, rather than the vehicle. The book that stays with your vehicle is the DVIR book. Your logs stay with you, whether paper or digital.
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    To expound upon that, you would have one ELD device. This device would connect to your ECM plug. As you switch vehicles you take the ELD with you and upon entering the new vehicle you change the info pertaining to that vehicle on your logs on the ELD. Thus your logs on the ELD would be kept current on lines 1-4 and prior 7 days.
  5. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    In Qualcomm, driver sign in using their driver number and it updates the logs via internet. The only thing that change is the unit number.
  6. Fatmando
    381
    446
    May 14, 2012
    Pittsburgh, PA
    Most companies have multiple devices, (one each per vehicle *or* one each per driver), and you log in to each with a driver identification. If the device is connected to the ECM, then it identifies the vehicle, that way, but many use wireless vehicle identifiers that require you to select from a list of vehicles within range, or you simply identify the vehicle manually. It is, after all, possible that someone else may be driving the other vehicle at the same time that he is driving the one that he's in...
  7. Mark Kling
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Since the OP uses one of his two trucks I am assuming the other one sits. I would think the OP would not be looking to put an ELD in each vehicle, but is looking for an option to use one they can transfer from one vehicle to another. The QC is more a hardwired device and the OP may be looking for a cheaper ELD.
    Many ELD's you simply plug into the Deuche Plug and it has a Dongle that BT's back to the users electronic device be it a phone or tablet. These run $149 - on up.
    If the OP decides to run two ELD's, then yes they simply log into that device and the information is transmitted back to a main source like a one ELD setup.
    Both a one ELD and two ELD setup will require a monthly subscription fee to be seen back to a common source other than the OP's electronic device they are recording on.
    The Deuche Plug setup would be more in line with the O/O's type of setup. Hardwired are more expensive.
    Not pushing these, but for examples.
    http://store.randmcnally.com/eld-50-e-log-device.html
    I know RM had other Fleet options, but I am not seeing them at this time.
    6wheeler Thanks this.
  8. 6wheeler
    2,696
    4,772
    Aug 30, 2009
    I could see in years to come, a digital countdown clock displayed on the side of the trucks showing how many hours are left for everyone to see.
  9. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    On comes the mission impossible theme song and a voice stating.... Vehicle will self destruct in 60 seconds unless parking brake is applied, once again you are on your own the government will disavow any knowledge of your existence.
    ramblingman Thanks this.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    I'm gonna get two elogs, the "man" is not gonna control me.
  11. Fatmando
    381
    446
    May 14, 2012
    Pittsburgh, PA
    There is a free elog app for Android and iPhone, called KeepTrucking, that offers the advantages of paper logs, with elog compliance.
