ELD causes truck to turn off?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by TruckerDaisy, Aug 7, 2018.
  1. TruckerDaisy
    TruckerDaisy Bobtail Member
    11
    Mar 31, 2016
    We are using the T-Mobile Sync Up Fleet ELD. Maybe we're the only ones, because there seems to be nothing about it anywhere. It's great for us, but since we installed it (simple plug in just like many others) the truck randomly shuts off. All power goes off, engine shuts off, then all comes back on. It first happened while driving down the road (scary), then happened while parked with engine idling, then also while parked and engine off but key turned to accessory, and even once while the key was not in the ignition and everything was off (it kills all power, even lights, that's how I knew it happened).
    This is in a 2017 Western Star 5700xe. We previously had an Omnitracks installed by the company we leased to and now have our own authority.
    I have unplugged the eld now to see if it will happen while sitting here. May go on paper logs for a day to make sure it's the eld causing it.
    Anyone else have this issue?
  3. Call_Me_The_Breeze
    Call_Me_The_Breeze Medium Load Member
    504
    441
    Dec 30, 2015
    I had a similar electrical shutdown in a Pete 386 I drove. 10:30 pm in a curve, no moonlight, engine, lights, everything shut down. I had to get the truck stopped dead stick on residual air pressure with no lights and couldn't see a d-mned thing. I got lucky.
    Mine was an electrical control module problem. Possible yours is the same and just happened to coincide with the new setup. I'm no expert, but all these plug-in dongles do is tap into speed sensor signal to tell the ELD via Bluetooth whether the truck is moving.
    It is possible, however unlikely, that this may somehow cause an open circuit fault in the speed sensor circuit and cause the ECM to wig out. However, I'm thinking this is an electrical control failure, or perhaps something was damaged in the the removal of the Omnitracs.
    06driver and Bank_Lbr Thank this.
  4. TruckerDaisy
    11
    Mar 31, 2016
    Well, I know this one does more than that because there are features that allow it to shut down the truck after a certain amount of idling for instance, but I have all of those things turned off. It also doesn't use bluetooth- it has a SIM card and connects directly to the T-Mobile network. Still, it would have to be something strange to be shutting the truck off.
    Been sitting here for several hours without it connected and no shut down yet...
  5. Call_Me_The_Breeze
    504
    441
    Dec 30, 2015
    o_0
    So, I wonder if it might be possible that the device loses contact with the network long enough that it tricks the system into thinking idle shutdown is necessary, and does it anyway? Just a thought.
    Bank_Lbr Thanks this.
  6. 8thnote
    8thnote Road Train Member
    1,980
    3,686
    Aug 12, 2013
    Chattanooga, TN
    We run Peoplenet on our fleet. We've had issues with it on trucks with automatic transmissions. Apparently the road speed is read by the peoplenet thru the TCM (transmission control module) on trucks with auto shift transmissions. It causes an overload of data flowing thru the port and causes the transmissions to shift into neutral and lock down while the trucks are going down the road. The only way to reset it is to have the driver coast to a complete stop (hopefully they make it onto the shoulder), turn off the ignition and let it sit for several minutes. Only then will the transmission shift out of neutral. It's happened several times so far on 3 of our trucks (all '16 Pete 579s with Paccar engine and Eaton 12 speed auto-shift trans).
  7. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,408
    Aug 28, 2009
    Airlie Beach QLd
    That is scary and down right dangerous something is going hay wire in your truck that's for sure, going to have to get the computer boffins out and the electrician to sort this one out.
  8. TruckerDaisy
    11
    Mar 31, 2016
    No, we have been sitting here in a spot with a great signal and still happens.
    I found an exception report in my software that shows "unauthorized device removal" that corresponds with every time it has happened . Hmm.
  9. Call_Me_The_Breeze
    504
    441
    Dec 30, 2015
    Sounds like a loose connection in your diagnostic port or possibly a short circuit in the device itself. Apparently it thinks it has been removed.
  10. americanvolo
    americanvolo Bobtail Member
    8
    Dec 6, 2019
    I have the same fealing, that eld cause this problem. I have keeptracking, truck started doing the same things as yours. I found a different thread explaining my problem:
    Losing throttle completely
    But cant find any solution yet.
  11. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
    I would contact HQ about issue, quickly get a new one, then see if other drivers are experiencing the same issue, I for one wouldn’t drive that rig until issue is fixed.
