EGR Valve took a dump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cowpie1, Sep 9, 2010.
  1. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Well, it finally happened. My '06 ISX egr valve decided to give up the ghost. Got a fault code the other day, so stopped in my dealership to have the code checked out. Sure nuf, EGR died. Code won't go away until changed.
    Well.... since I have a block installed where the EGR tube enters the intake, I never noticed a change in operation except for the fault code. Oh well, looks like I will have a dead EGR valve on my engine for a long, long time. EGR has had no effect on my ISX for about 200,000 miles since I first went the EGR unplug route and then finalized on stopping up the plumbing at the intake. Bill, my very knowledgable Cummins tech at the dealership just chuckled when he told me that the EGR valve took a dump. He has known all along that it wouldn't mean anything to me since he knows what I did to eliminate the EGR problem with the ISX. Told him that the dead EGR will just have to sit and be dead. He agreed, why spend money on something you don't use anyway.
    Cummins won't be able to make a buck selling me one of the darn EGR valves!
  3. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Somewhere Al Gore is crying, don't you feel bad?:biggrin_2559:
  4. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Shame on you... you are now 'officially' guilty of causing more non-existant man-made global warming... a polar bear is probably stranded on an ice flow as we speak...
  5. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    yeah.... just makes me feel all torn up inside. Putting more of that darn NOx in the air, but putting far less carbon since getting average .8 mpg better not having that EGR working. Guess it is just a tit for tat. Sometimes, a body just can't win!
  6. The Truckist
    The Truckist Medium Load Member
    342
    245
    Sep 11, 2010
    Cowpie...I am too new around here and can't send PM's to you. I am interested in what all you have done with the EGR valve delete. Are you the gent that installed a PDI performance manifold? I just started a new thread about the EGR & EGR cooler then I saw this.
    I wondered if even though the EGR vavle is unplugged, would it eventually get "cooked" and throw codes? I'm working with a Pete with a 2006 565 ISX. Cummins has expressed to me that heat is the killer for the internals on this EGR valve which is why for later newer models, the EGR went to the left side of the engine. Mine is sitting right there eating all the turbo heat. I am, BTW, on my 3rd EGR valve and the last one was not pretty. I refuse to go through that again.
    Thanks.
  7. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Yes. I did the PDI intake manifold and blocked the EGR tube at the intake. Originally, I had the EGR valve unplugged for roughly 180,000 miles. Then I did the intake. When I took the truck into Cummins for another issue, they went ahead and plugged the EGR valve back in. Then it took a dump.
    Heat is the big killer of the EGR valves from the first ones until Cummins moved them over to the cool side. The only way to avoid going thru EGR valves is to modify the EGR in such a way, that if the valve does give up, it really doesn't make a difference. Unplugging the valve or blocking the EGR tube, right now anyway, is really the only options so far. There are some complete ECM reprogram methods out there that eliminates the EGR function in the engine computer. I am not totally comfortable at this point with a reprogram of the ECM. And the cost is not cheap. Well over $2000 for this way to do it. The unplug is free and blocking the EGR tube is only a few bucks. I chose the cheaper way. Maybe in the future, when there is plenty of experience with the ECM reprogram and it is shown to not be a problem also, I may go that route. Probably will wait until an engine rebuild.
  8. The Truckist
    342
    245
    Sep 11, 2010
    Thanks, CowPie. I'm getting a little puff of white smoke now at various times and I believe it is the EGR cooler allowing some coolant to hit the exhaust port. Please see my thread here when you have time and feel free to share your experience if you have had EGR cooler issues. Thanks.
  9. rhino3hh
    rhino3hh Bobtail Member
    18
    Jan 25, 2010
    Jamestown, NM
    Cowpie on your setup do you have 4" exhaust coming off the turbo. I was lookin at my dads yesterday and think i'm gonna fab a new tube where that inlet is to get rid of that horrendous neckdown. i will post some picks when i get it done.
  10. CaliforniaOvernight
    CaliforniaOvernight Light Load Member
    85
    23
    May 14, 2010
    Pacific Grove, CA
    I would call Holset 1-800 line and ask them why is it like that. I'm pretty sure there is a reason for it
  11. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    You mean like this?
