Egr cooler finally went.
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Apr 2, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    937
    Jan 11, 2022
    How long do I have to fix it until more damage is done? I just started a 3 to 4 ish week tour.
    77fib77 Thanks this.
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    ASAP
    depending on your truck it could be quick to have a nice mix of oil and coolant.
  4. Arctic_fox
    3,861
    19,404
    Sep 16, 2016
    You should get towed asap. Dont run the truck ive seen people cook blocks doing that.
  5. Keepforgettingmypassword
    738
    937
    Jan 11, 2022
    Whats your opinion?
  6. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    Where is the coolant leak coming from? At the banjo bolt? If your EGR cooler was leaking coolant internally, which you probably wouldn't be able to see, that's when it can cause problems. The coolant mixes with the gas and goes back into the combustion chamber and can damage components and contaminate DOC/SCR, or cause the DPF to get plugged easier.
    I would still fix it soon, because even if you can continue to top off the coolant and run, you're going to have a huge mess and it will be hard to tell if it's just that leak, or if it's coming from somewhere else.
  7. Keepforgettingmypassword
    738
    937
    Jan 11, 2022
    Minor update: as I will post more in the next couple days.
    Some one walked over and looked at in person for me today. They said clean that bolt and put a regular hose clamp on it and check it every time you stop to see if that fixes it. If not then dig deeper.
    When I showed time the small amount of soot in the coolant. About 5 tea spoons worth. And then I explained the six weeks I just spent fighting the different sensors. Because of the soot build up. He said its for sure leaking. But not gone at this point.
    I will clean that bolt and reclamp it in the morning.
    @loudtom om thank you for that explaination
    Siinman Thanks this.
  8. loudtom
    1,717
    2,800
    Aug 26, 2016
    If you think there's soot in your coolant, it's probably leaking. If you disconnect the exhaust pipe from the EGR cooler, it might help verify that. The coolant can make the soot sticky and causes it to get plugged up quicker. Just keep in mind that even if you don't see it plugged up, it might be happening further back where you can't see. This is just to reinforce the idea that it's leaking, not to eliminate that as a cause.
    Another thing would be to remove the DOC/DPF and inspect it for coolant stains. If the cooler is leaking, you'll probably want to get them cleaned anyway.
    If you drain the coolant to repair the hose, keep in mind that you might have to top off the coolant initially due to air pockets that can form. If you keep having to add coolant after that, then I would fix it before running any more. It's a good idea to find out if shops currently carry the EGR cooler due to parts shortages.
