EGR Coolent
Discussion in 'Volvo Forum' started by Kai kassar, Dec 21, 2017.
  1. Kai kassar
    Kai kassar Bobtail Member
    Dallas. TX
    Hello
    I bought my truck Volvo 2013 670 D13 two months ago , 3 weeks ago i replaced the turbo after couple days the truck started shacking bad , i found out there was something wrong with the EGR coolent , i've talked to couple friends of mine they've asked me to delete it
    My question
    Which is better have it fixed or delete it
    If i wanna delete it could it lead to more problems or less
    Thanks.
  3. HighwayD
    HighwayD Light Load Member
    58
    61
    Nov 15, 2017
    Pennsylvania
    Are your friends qualified to give that kind of advice? Everyone talks like a mechanic when its someone else's truck...
    KB3MMX and Sharky88 Thank this.
  4. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Fix it. Especially if you run out west you will need it. Removing the egr cooler also means removing all the emissions equipment as well. Yes some people will do that but it usually causes problems in the future. Also it's real hard to have the dealer reprogram the ecm as the truck was not spec'ed to run with out it. Sa highways says it's easy when it's not their money
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Keep the cooler but Braze it shut on air side and coolant side, repaint and leave intact in place. Stock looking.
    Reprogram the ECM to not throw codes. Look up PDQ Performance , Sanford FL
    Socal Xpress Thanks this.
  6. HighwayD
    58
    61
    Nov 15, 2017
    Pennsylvania
    I would have to agree with Sharkey on this one. Good luck!
