EGR code question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Phoenix Heavy Haul, Jan 31, 2023.
  1. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    I got code Spn-2791 and Spn-3058.
    The CEL is on but no active codes in dash display. I pulled codes from ELD.
    Per google this is indicates the EFR actuator isn’t working properly.
    I have verified the actuator arm moves when I switch the ignition on.
    I’ve also checked the wiring harness and it has no oil or moisture.
    Anything else I can check?
    And what will happen if I continue to drive it?
    I’d like to get these loads done before I go to shop.
    D.Tibbitt and kemosabi49 Thank this.
  3. kemosabi49
    10,435
    44,383
    Jan 13, 2013
    SW Arkansas
    I had the same codes on the International I drive. I kept driving until I got back to the yard but the light had went back out by then. Did that for a few months. They eventually changed the EGR valve.
    LoneRanger and Phoenix Heavy Haul Thank this.
  4. Phoenix Heavy Haul
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    Thanks!! My light is intermittent. Just wanted to make sure it wouldn’t cause any additional problems or derate. It done a regen today while driving so that made me feel better.
  5. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    I have a similar issue, can you clean the EGR valve? I keep getting engine lights on the dash which I think is because the EGR valve is all sorted up
  6. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
    could be soot build up, if you can remove it and clean it, it should continue to work. Just sometimes it can’t open or completely close, because of the build up.
  7. Phoenix Heavy Haul
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    From the coolant I found in my EGR cooler today it appears that’s my problem.
    I’m wondering if the code is being caused by the faulty EGR cooler?
    And of course there is no EGR cooler to be had, they are back ordered and have no eta. So ima take it off and take it to a radiator shop and see if the can fix it or rebuild it.
    D.Tibbitt Thanks this.
  8. LoneRanger
    3,661
    9,445
    Jun 3, 2018
    not sure if the egr cooler leak will cause a egr fault code, as generally if the actuator isn’t opening and closing correctly will throw that code.
    When you opened it up, was it dirty inside? Soot build up?
  9. Phoenix Heavy Haul
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    The cooler didn’t look to bad, from what I could see. It was definitely some soot but not any build up.
    The “cold” pipe on driver side was really clean with zero build up, just some signs of coolant.
  10. LoneRanger
    3,661
    9,445
    Jun 3, 2018
    is your egr actuator the new style or old style? You happen to have an image of it?
  11. Phoenix Heavy Haul
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    Naw I can grab one in the morning. But it looks newer.
