Edge protection?
Discussion in 'Flatbed Trucking Forum' started by TooTiredToTalk, Apr 18, 2022.
  1. TooTiredToTalk
    TooTiredToTalk Medium Load Member
    636
    2,935
    Feb 24, 2022
    Okay....more or less these are the same pics. Anyhow, obviously I'm learning everyday BUT no matter how seasoned ya are, if you don't learn something everyday, there's something up!! Opinion.....I was trying to figure out if they needed edge protection (to protect the straps).....it wasn't sharp, but where the cross bars were welded the straps would stick or get stuck. I feel like it would need edge protection, but what is everyone else's thoughts??
    I was only going 33 miles so no biggie BUT I want to know these things and learn these things :) 20220418_110859.jpg 20220418_110836.jpg 20220418_110831.jpg 20220418_110819.jpg
  3. PSM379
    PSM379 Heavy Load Member
    893
    3,556
    Apr 19, 2019
    I’d use edge protectors on that.
  4. Czar_Zero
    Czar_Zero Road Train Member
    1,665
    22,529
    Mar 20, 2018
    Orebegone.
    I'd of thrown edge protection on those as well, just because this is a job where erring on the side of caution isn't a bad practice. Doesn't take that long to put the edge protectors on and they certainly aren't going to hurt anything.
    Also, a bit of friendly advice.. "It's only going XX short miles" is something you need to eject from your mindset and vocabulary with a quickness.
  5. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    Edge protectors as well
    I use edge protectors in places I’m sure I don’t need it but it isn’t an all day ordeal to put it on. Maybe a couple minutes tops
    Also. An extra strap at times for the same reasons
  6. Rickp
    Rickp Heavy Load Member
    765
    1,070
    Apr 14, 2016
    Ward, AR
    Id use edge protectors.
  7. D.Tibbitt
    141,049
    My rule of thumb was to run my bare hand along the edge of the freight and see how sharp it is.. To sharp for your hand then to sharp for a strap... Anything with a rounded edge It usually didn't need edge protectors.. Anything with a square edge its most likely going to need edge protection
  8. sbaumann14
    sbaumann14 Road Train Member
    1,215
    1,389
    Sep 1, 2010
    Rhinelander, WI
  9. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    It takes less time to put on load protection than the time you'd spend listening to a customer whine at you for not doing it.
  10. beastr123
    beastr123 Road Train Member
    2,803
    22,847
    Jan 2, 2014
    Moose Jaw SK CAN
    Sorry if I sound like a grumpy old teacher but:
    If you are asking the question then you already know the answer.
    Please put it on if you think it "MIGHT" need it, nobody can fault you for being cautious.
    I don't care if it is going 33 miles or 3000 miles you tie down the same way, you are securing against the idiot driver that is out there looking to get you. You want that load to be on that trailer if someone hits you and it ends up overturned in the ditch. This means it is not on the road where some texting fool can run into it.
  11. GYPSY65
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    Reminds me of a snow and ice storm I was going through in Mount Vernon
    There was a flatbed in the ditch with the trailer on its side
    Load still fully secured to the deck
    Some guy on the CB goes. At least dot can’t get him for improper securement
