ecu 128 and sid254 cascadia with cummins isx
Discussion in 'Freightliner Forum' started by swaranjitdhaliwal, Apr 28, 2015.
  1. swaranjitdhaliwal
    swaranjitdhaliwal Bobtail Member
    hi guys
    can you please help me on this
    last month mechanic fix exhaust manifold bolts and he removed turbo and whole parts on passenger side of cummins to get it fixed and after that my truck always shows these codes ECU128 and sid 254 and these guys always show up with engine light on it can be on anytime of day and goes off when i restart the truck this is 2011 cascadia with cummins isx 450 st and 250000 miles on it
  3. ColoradoMobile
    ColoradoMobile Bobtail Member
    7
    4
    Apr 29, 2015
    Denver, Colorado
    254 Engine Fuel Shutoff Valve Driver Circuit - Voltage Below Normal or Shorted to Low Source
    The fuel shutoff valve is located near the fuel pump, has a single wire going to it. Grab a dvom check resistance. should be 6 to 15 ohms. If not the solenoid is easy to replace, and parts come in a complete service kit.
    swaranjitdhaliwal Thanks this.
  4. swaranjitdhaliwal
    thanks for your help guys solenoid has been replaced now new codes come ecu 128 and sid 251 is anybody has any clue
  5. ColoradoMobile
    7
    4
    Apr 29, 2015
    Denver, Colorado
    251 is a lost of power to the ecm while the key is switched to the on position. Can you see how many counts this code has? Most common situations I see with this code is a driver will switch the main kill switch off to kill battery power before turning the ignition switch off. Other causes could include removing the batteries with the key on or loose cables. Rare causes would be damaged or restricted cables, or an incorrect power source to the ecm (ie the unstitched battery supply voltage should be off the battery, we have seen some coming from the starter)
  6. swaranjitdhaliwal
    thanks for your help i will try tomorrow i think today my shop guy cleaned the batteries and replaced solenoid i think he did something with battery terminals or may be with the ground as he is trailer mech any ways thanks for your great help bud
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    That is fault code 254, not SID 254.
    SID 254 is an internal ECM fault, which could be a power or ground problem causing intermittent or low voltage.
    SID 251 is similar, but specific to the ignition power or realtime clock.
    Hopefully you find some bad wiring connections, but the worst case scenario is a faulty ECM.
    Those codes should also give an FMI, which will help narrow it down better.
  8. Husk
    Husk Bobtail Member
    Jun 23, 2016
    Hi guys. I have 2011 cascadia with cummins. I have this code on my dash board.. ecu128 sid 380 fail 11 can any one help me with this code when i take it to cummins shop they clear the codes and it just comes back.. code pops up and i loose power climbing little hills and i push the gas pedal more..appreciate your help guys
    Thanks
  9. Oleg Komar
    Oleg Komar Bobtail Member
    12
    10
    Mar 25, 2015
    I've got the same issue. Have figure out what was wrong with yours? Let me know, please
    7087242440 Thank You
  10. BIGBOY1994
    BIGBOY1994 Bobtail Member
    Hey guys I went through the code system here it showed me fault one then it went to cab 249 then Sid 254 after that it showed fault 02 I have a 2011 Freightliner Cascadia Cummins engine can anybody help me out with these codes what's going on with my truck my check engine light pops on for a while and then goes off
  11. MiguelAngel875
    MiguelAngel875 Bobtail Member
    Hola, yo tambien tengo la misma falla
    Me la acaban de reportar
    Encontrando algo de información la comparto
