ECM harness repair ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Exiled, Dec 5, 2014.
  1. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    Is it possible to repair it?
    i had those loose wires @connector ,an electrician came and managed to add more damage by cutting the protection rubber and one wire
    DECC V
  3. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I've bought pins and a power plug for a DDEC4 from Detroit.
    Exiled Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    They can be repaired, but it depends on how bad it is to know if a new harness is worth the time and money. If it's just a few wires, I'd repair. I've seen many DDEC V's with chaffed wires from the plastic cover at the ECM. If the insulation is just chaffed off and you caught it before any signs of corrosion, liquid electrical tape works. But if there is any corrosion or broken strands, that's a future problem waiting to happen. Then it's best to replace the pins in the connector use new wire as long as you need to get good clean wire to solder to. Use good heat shrink that has sealant in it.
    Once you fix it cood, clearance the plastic cover so it doesn't happen again.
    Exiled and flat top Thank this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    really deutch supply contacts, pins, insulators... but u need some tools, like extractors for example
    Exiled Thanks this.
