Just had my engine inframed ! After 30 hours running time I shut it off to check the oil and it wouldn't start ! Service guy hooks up laptop to her and says ECM is showing it's not getting power ! Dow I get the ECM tested or just go with a new one ?
ECM for a 60 series Detroit 515
Discussion in 'Western Star Forum' started by Crudehauler ted, Feb 8, 2014.
Ck. fuse in fuse box, one in BATT. box also.
My fuse isn't in the battery box. My mechanic thought it was. It's up close to the firewall under the hood. So if you don't see one in the box check there also. Mine did almost same thing.
Fuses were all checked !
Then find the pins that are supposed to have batt power, key power, and ground. A DD shop should be able to tell you the pin numbers.
PIN numbers for ?
Not PIN (personal identification number), pin in the ecm plug. IE what wire going into the ecm plug should have batt power, key power, and ground. Remember, the ecm needs a perfect ground as well as both powers.
Crudehauler ted Thanks this. -
Oh ok ! Well my new ECM is supposed to be ready tomorrow ! I'm really hoping this money pit starts right up after I install it ! But thanx for the info so far !
Check brown wire coming off battery's.small14 gage wire.you should have a large fuse box junction right above batteries.that wire powers up the ecm
Check that wire with test light.the wire is out in the open and can crack and turn green.this is common problem on these
