Is 230* too hot? If it matters its a RTLO18913 in a freightliner coronado. My thought is the trans cooler is on its way out. It's the type that flows coolant through. Any thoughts ?
Eaton Transmission Temperature?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 01blackz28, Jul 19, 2012.
Page 1 of 3
how hot was it outside and were you running heavy in hills? if the water cooled trans cooler was going out, one of two things either you would be getting antifreeze in the trans grease. or you would have a major leak around the cooler either grease or coolant. it could be getting pluged up but thats unlikely. 230 isnt that bad if you were pulling in hills on a hot day. i switched to an air cooler for my trans and the hottest it will get is about 180deg. on a heavy load pulling in the hills. i will say what an old timer said to me long ago. to fix that problem unplug the dang guage and problem solved!
Guf, x1Heavy, Oldironfan and 1 other person Thank this. -
Ah 107k not too heavy but it was 90* and all hills
Trans cooler took a crap today. Lost coolant and had gear oil in the coolant reservoir. I knew something was wrong lol
Justrucking2 and Oldironfan Thank this. -
Been there got the t-shirt. Get rid of the water cooled setup and go with air cooled. Cheaper and more reliable. Mine seldom ever goes over 200* anymore. On hot days with ambient temps of 100* and heavy loads in hills and mountains it might get up to 225*. That is when I pull over for 20 minutes and let it cool back down. For the most part I never see those temps though. What I blame for seeing it get that hot on occasion is the fact my T600 is an aero truck and the air just does not flow well enough underneath it to properly cool the trans. Nobody I know with a W900 or 379 ever has high trans temps hauling normal 80K gvw loads.. Another drawback to the wonderful aero trucks. I'll trade longevity and performance for a little fuel mileage any day of the week that's why my next truck will be a hood...
Triple C, Oldironfan and JimmyWells Thank this. -
I have no cooler at all and see temps over 250 degrees on a typical basis. Apparently according to TruckPro, they stated it's normal. I don't believe so but they're the ones who took the oil cooler off.
I get freaked out when mine reaches 190°. On hot days loaded to max legal weight , it runs right at 180° When it's cooler outside, 150° maybe 160°
Oldironfan, x1Heavy, snowman_w900 and 1 other person Thank this.
Page 1 of 3
