Hey fellas looking for info on how and what gears to "flip" to turn say a rto 15613 into a rtoo or double overdrive I have read flipping gears is all it is but figured I would ask on here to see if anyone knows which ones or if there are other issues
thanks!
Ryan
Eaton Rto to rtoo how?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ryan151, Mar 25, 2014.
You have to flip 2 countershaft gears left to right which in my opinion makes them howl worse than new. You also need to buy three gears to make it all mesh. I ran one for a lot of years still miss it.
Thanks sir you don't happen to know which gears gear to flip exactly? And also I suppose which ones to buy should be straight forward after ya flip em though I suppose
I can almost remember the part numbers you need from memory I just can't quite pull it out, sucks getting old. I do have them home and will post them later in the week when I get back around there. I ran alot of updated parts in mine as well that I could post. I get the numbers you need I will post a short how too, Its pretty straight forward. If you have never worked on an eaton trans I suggest getting some one that has to help or I will try to be more specific
Okay perfect! Ya I just need to know what gears to flip and what else is needed
