I have noticed a vibration underneath the drivers seat and the pedals usually under heavy pull. As i was greasing i shake the drive shafts for play, and noticed that the output on the tranny had quite a bit of play. The seal is also leaking on. I am wondering is this something a guy can replace himself? I read that the rear cover has to come off. What steps need to be taken to replace the output bearing? Thank you!!!
Eaton Output bearing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 21blaumeyer, May 2, 2024.
Rideandrepair, 21blaumeyer, Big Road Skateboard and 1 other person Thank this.
I would start with torquing the existing nut. If the play in the yoke tightens up then pull the yoke and inspect it. Can't remember if you can pop the rearmost bearing out. If you can, give it a look over. If all good put the bearing back in, install a new seal and torque the yoke up with a new nut. Might save you from a lot of work
If torquing up the old nut doesn't take the play out, its time take it apart to see why.Last edited: May 2, 2024
Rideandrepair, 21blaumeyer, JB7 and 1 other person Thank this. -
Agree with both above. You can tighten it with a chisel without dropping the driveshaft
See if that eliminates your slack. If so, yes, new nut and seal will fix you up.
Personally, I bet the vibration is coming from further backRideandrepair, 21blaumeyer and BoxCarKidd Thank this. -
Rideandrepair, 21blaumeyer and AModelCat Thank this.
Thanks all of you guys and you are on the same page. I agree with tighten it with a chisel. If that took the slack out that is great but it will never stay. Pull it down, do the new seal ( wear ring ) nut (They are considered a one time use item) and go again.
You never said what transmission you have so I am assuming that is a twin counter shaft transmission. Those have two bearings facing each other like a wheel bearing in a car but have a spacer between them. If they have been ran loose long enough the races begin to spin in the housing. The housing is worn. No bearings races or nuts will fix that.Rideandrepair, 21blaumeyer, Big Road Skateboard and 1 other person Thank this. -
BoxCarKidd, Rideandrepair and xsetra Thank this.
