Eaton Fuller smart shift trans won't shift into gear
Discussion in 'Questions From New Drivers' started by charris, Oct 20, 2015.
  1. charris
    charris Bobtail Member
    9
    Mar 3, 2013
    Burton, OH.
    I have a 2007 Columbia with a Eaton Fuller Smart shift Transmission it won't go into gear it keep flashing check trans light, and when I checked the code it showed 56 which is input shaft speed sensor. should I replace the speed sensor or is there something else going on.
  3. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    shut off engine, remove key from ignition and wait EXACTLY 10 minutes
    retry.
    flood Thanks this.
  4. lagbrosdetmi
    lagbrosdetmi Box Monkey
    547
    985
    Jul 1, 2014
    Detroit
    ^^ this cures 97.335% of all truck issues.
  5. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    That would help. It needs that sensor input to determine when the input and output shafts match in order to shift.
  6. charris
    9
    Mar 3, 2013
    Burton, OH.
    I tried it did'nt work. I even tried disconnecting the battery for ten minutes
  7. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    i never actually said it would work.
    starmac, ChaoSS and TROOPER to TRUCKER Thank this.
  8. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Unplug the sensor and try it. If it doesn't work then. Keep it unplugged get a paper clip make a "U" shape out of it and stick it into the sensor plug.
    This fixed my shifter problem in my 07 Columbia smart shift(kept blowing fuse)
    Low coolant sensor
    I replace fuses with paper clips hahaha.
    But like G, Anthony said I'm not saying it's going to work it's a suggestion lol
  9. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    many truck fires, start......
    with a paper clip...
    jus, sayin' is all............
    Tx Countryboy, starmac and ChaoSS Thank this.
  10. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,652
    12,685
    Dec 15, 2014
    Charlotte, NC
    or a properly placed screwdriver
    G.Anthony Thanks this.
  11. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Or being built by Navistar.
    tech10171968, S M D and FinkPloyd Thank this.
