Eaton fuller 8triple L with 3rd in the four slot.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mattnatti, Jul 28, 2014.
  1. Mattnatti
    Mattnatti Light Load Member
    239
    176
    Jul 10, 2014
    Cincinnati, Ohio
    Most of the dump trucks at work have 8 LLL with the exception of the one I cut my teeth on and a international tractor. The one in my 95' Ford L9000 has a 8LLL but the 3rd gear is in the four slot. Just wondering if this is called something different and why is it set up different ?
    Thanks for for the input.
  3. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    Sounds goofy.....like a Mack 7-speed....
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    double over 8LL maybe?
    iv drove a double over 9 that had the u shaped shift pattern.
    most people refer to that shift pattern as a u pattern as you go left up left down around the corner to right down with top gear to the dash.
  5. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Well the term double over isn't really right. My old thirteen double over was the horseshoe or u pattern. The term double over came from a over drive in the front box driving an overdrive in the back box. Since the aux box on a double low is deep reduction there is only one over gear. Some where in the later trans missions they put a thrid rail in to make a u pattern an H pattern. I am so used to the horseshoe pattern I put an older top on my 20913B which made it a horseshoe pattern instead of an H pattern.
    Mattnatti Thanks this.
  6. Mattnatti
    239
    176
    Jul 10, 2014
    Cincinnati, Ohio
    The senior truck driver at work said he thought it was called a " military " pattern. I kinda like it and it became natural in no time flat to shift like that. I thought it would be a pain in the keister to learn but it wasn't. Now that I am driving our dump trailer the tractor has a 8LL ( no deep reduction ) ? , and i find myself slipping it into 4th when I shouldn't. :banghead:
    Thanks for for the post guys, much appreciated.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    No such thing as a 8LLL, I'm sure it's an 8LL and has an over drive in the main box which is why high is up against the dash.
  8. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I've always heard it called simply "reverse pattern 8 spd" or 15 whatever the case may be. I missed it also when I went to an 18. No real reason though. When you were b.s.ing with other some guys would call it "going home gear " when the stick was up against the dash.:)
  9. Mattnatti
    239
    176
    Jul 10, 2014
    Cincinnati, Ohio
    going home gear.....nice. That's what I will call it now.
    Thanks smokincat, I thnk this pic will explain why I called it a 8LLL. Misunderstanding.
    BTW, the old L9000 has a 3406 in it as well( read your sig line ) but not sure if it's a C or a D. From what I have read about the 3406 I will assume it's either one or the other considering the age of the truck. It's a gravel humping motor. Easily the most reliable and cost effective engine in any of our dumps including the 13' Mack.
  10. j_martell
    284
    184
    Jun 12, 2014
    Both our 8LL have over drive in the main box (4th slot), and uses a standard H pattern.....I don't get what your getting at....
  11. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    You probably have a X series top plate that allows it to be shifted that way.
