Eaton Fuller 8 speed loose stick, and is flopping around.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JDO, Aug 22, 2021.
  1. JDO
    JDO Bobtail Member
    7
    Aug 20, 2021
    The stick on my Eaton flops around every which direction in gear or out of gear.
    The model number is RT0F-14908ll
    Anyone know which shift stub kit I need? Or how to find the right one?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    The Eaton Tranz. have most all use the same rubber bushing that has pins thru the base of steel shaft that sticks up out of top of trans. and will be frozen in place, if you pull up the rubber that goes into the floor of truck and has gotten salt spray all over it for years and willl take a lot of wd/40 or what ever you wish to start off putting on it before you start trying to pushing it or beating it thru the lower Shifter steel shaft?
  4. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    A good C-Clamp, deep well socket, and short pin to push old pin out works really good to get those pins out of the isolator bushing.
  5. Big Road Skateboard
    5,695
    29,706
    May 2, 2021
    Yep, needs am isolator kit. Do yourself a favor and do the big o ring on top of the stub shaft ball. You'll have to pull the tower spring. When they wear out it pushes the stub shaft up, and the stick comes out of the shift rails
  6. JDO
    JDO Bobtail Member
    7
    Aug 20, 2021
  7. JDO
    JDO Bobtail Member
    7
    Aug 20, 2021
    Anyone know?
