Eaton Endurant transmission problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MicksRule, Feb 25, 2023.
  1. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Yes the TCM will log the faults and store them, as long as nobody hooks up and clears them.
    Be careful with universal tools. Sometimes they can clear all modules.
    MicksRule Thanks this.
  3. MicksRule
    MicksRule Medium Load Member
    411
    354
    Dec 20, 2009
    Apple Valley, CA
    I'm going to go ahead and check with the nearest dealer in the morning to get it checked out.
    I do appreciate your feedback on this.
    Goodysnap Thanks this.
  4. MicksRule
    411
    354
    Dec 20, 2009
    Apple Valley, CA
    Got another question for you.
    Would there be any way to get a chassis wiring diagram for my truck? It's an earlier build '19. It does not have the new style eld connector in it.
    I'm getting the feeling I'm being bullshitted about my truck in a local Peterbilt shop. I have it there for that trans problem and for no power to the truck side pigtail center pin.
    Also, would you happen to know of any common areas where the chassis harness may short or open circuit?
    Crude Truckin' Thanks this.
  5. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Please send PM with last 8 and your e-mail.
  6. MicksRule
    411
    354
    Dec 20, 2009
    Apple Valley, CA
    Sent. I appreciate it.
  7. Coma1
    Coma1 Bobtail Member
    16
    19
    Oct 31, 2019
  8. Coma1
    16
    19
    Oct 31, 2019
    Hello ,am having this same issue right now on my 2019 Kenworth W990.What was causing that.Was it fixed?If so was it under warranty since the Eaton Endurant transmission is 5yrs/750K.
  9. MicksRule
    411
    354
    Dec 20, 2009
    Apple Valley, CA
    Wasn't fixed. Once I got out of the freezing wheather, the problem went away never to be seen again. There were some low voltage codes, according to the dealer, and they could never verify the actual problem.
  10. Coma1
    16
    19
    Oct 31, 2019
    Okay thanks for the reply
