Eaton clutch brake 2013 prostar maxxforce.
Discussion in 'International Forum' started by q258, Nov 30, 2018.
  1. q258
    q258 Bobtail Member
    25
    8
    Sep 19, 2018
    2013 Prostate maxxforce w/Eaton 10 speed.
    Is it really the case that this single piece clutch brake is not replaceable with a two piece and the entire transmission has to be dropped to replace a clutch brake???
  3. joejffrs
    joejffrs Light Load Member
    54
    14
    Jul 24, 2018
    San Diego
    The single piece clutch brake can be removed, having it done next week. The tranny shop said if they can’t cut it out then they would use a cutting torch. No trans removal.
    magoo68 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    It is possible.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I take them out with a torch. Tell the customer it is a 2.5 hour charge upfront. That is to replace brake and adjust clutch without removing the transmission.
    HopeOverMope Thanks this.
  6. AModelCat
    154,481
    Someone's trying to #### you without any :ky:
    Bet you anything they plan on doing it without pulling the tranny and then handing you a bill for 10 hours labour.
    spsauerland Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    The more important question should be........why did the the clutch brake not outlast the clutch and what can I do to prevent failure in the future?
    Yes it can be done.......not a pleasant job by any means, depending on the amount of grease present.
    Depending on the life remaining of the clutch, miles, use ect......I would just consider putting a clutch in it and going with the original one piece.
  8. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    That is normally correct but I did finally learn to adjust the brake a bit on the loose side for some customers. Slip seating new drivers and some must use it to stop the vehicle. Grease the disc also.
    spsauerland and Goodysnap Thank this.
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Yup........really easy to push too hard and tear it up, especially with a hydraulic assisted clutch. Not so easy to do with manual linkage.
    spsauerland and BoxCarKidd Thank this.
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
  11. q258
    q258 Bobtail Member
    25
    8
    Sep 19, 2018
    They didn't even try to pursue dropping the tranny. They originally thought it could be taken out with a torch but then called and said the hydraulic clutch cylinder was interfering and to just let it go until the clutch needed to be done.
    Don't know what caused it to be worn out other than normal wear perhaps. Haven't been in this truck very long and it was gone when I got in. Perhaps the previous driver did too much incorrect (deep) pedal. No clue.
    Really just a minor inconvenience from my perspective requiring a bit more proactive gear selection.
    Thought someone here might have some specialized insight into THIS truck.
    Appreciate the replies.
