Eaton 18 speed models
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Oct 7, 2017.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    how many different models of the Eaton 18 speed are there
  3. okiedokie
    okiedokie Road Train Member
    15,141
    124,222
    Jun 13, 2011
    PNWET
    I've driven alot of 18s and they were al the same.
  4. Oxbow
    Oxbow Road Train Member
    13,985
    146,146
    Nov 24, 2015
    I'd have to go back to the chart to answer correctly, but there are torque ratings from something like 1450 through 2250. Some are overdrive @ .86; some are .86 and .73. Then you have RTLO, RTO, RTOF, and maybe RTX. They all shift the same as far as I am aware though.
    SAR Thanks this.
  5. truckerbangin
    268
    45
    Jan 22, 2013
    Are there single overdrive 18speeds available or they only come bouble overdrive
  6. Oxbow
    13,985
    146,146
    Nov 24, 2015
    .86 single.
    SAR and Bean Jr. Thank this.
  7. fuller
    fuller Light Load Member
    203
    295
    Nov 21, 2010
    Canada
    Really very little difference at all in the 18 speeds, other than torque rating.
    One thing to be aware of, is that some have an oil filter. Usually they're only seen on the higher torque capacity models, like 2,050.
    Oxbow Thanks this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    I’ve had a few. All the same gearing, but the worst one had an air cooled transmission radiator mounted right above the transmission. It didn’t get enough air flow in there to keep it cool at low speed when I was climbing mountain grades. The transmission temperatures exceeded 300 degrees when climbing from Phoenix to Flagstaff and it was 104 degrees outside. Or pulling super b’s in the Canadian Rockies in the winter time at 140,000 lbs.
    All the other ones I had were cooled out front of the main radiator. No temperature problems with them.
    SAR and Oxbow Thank this.
  9. fuller
    203
    295
    Nov 21, 2010
    Canada
    My 1994 Kenworth has the rad mounted exactly the same way... Actually, sort of underneath where the drivers seat is!
  10. fuller
    203
    295
    Nov 21, 2010
    Canada
    Which reminds me... Tomorrow I should make sure the fins are straight, and ensure no debris is clogging it.
    Oh, the joys of owning... Even on a long weekend, there's still things to muck around with.
    OLDSKOOLERnWV and Oxbow Thank this.
