Eaton 18 speed leaking valve….
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bfroelle, Nov 6, 2021.
  1. bfroelle
    bfroelle Bobtail Member
    4
    Nov 3, 2021
    Sorry if there’s already been a thread posted about this, I’m a new member. I’ve got a 2006 KW W900l with an Eaton RTLO18918B transmission. So in the last few weeks my transmissions been pretty delayed in shifting from low to high range and vice versa (no grinding noise; it would just take an extra second or two to shift), until it wouldn’t shift into high range at all without some “encouragement”. Right about the time it had stopped shifting into high range I started hearing an air leak from from under the truck every time I would flip my Hi-lo range selector on the shifter. Looked under the truck and found the slave valve on the front driver side of the transmission was leaking air out of what I assume is a vent hole. Replaced the valve and let the truck build air, and it’s still leaking out of the same vent hole. Spoke to a local mechanic and he says the range cylinder probably blew an o ring. I was just wanting to get a second opinion and make sure it’s not something else. Any ideas?
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Oxbow, A5¢ and Ross_Tech Thank this.
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    You can start with removing the range cylinder cap and removing the piston off the shaft and put new o ring on piston. See if that seals it up. If not, I believe the auxiliary must be removed to install a new print on the shaft
    The high low splitter cylinder which is not your issue here can be fully serviced without removing auxiliary. Only requires draining the trans fluid.
    The Eaton service manual is free to read on Eaton’s website
    The publication number is trsm0670
    spindrift Thanks this.
  5. bfroelle
    4
    Nov 3, 2021
    Ok thanks for the input! I threw on a new filter/regulator today since I was throwing new parts at it, and still leaks out of the slave valve exhaust port. So I’ll get an o ring kit for the range cylinder. And just to to be clear, the hi-lo range cylinder is the one that’s sits behind the regulator, and the gear splitter cylinder is the one on the lower left when facing the rear of the transmission correct?
  6. Don379
    714
    1,286
    Jan 7, 2021
    yes that is correct. I actually tried to do a video of replacing hi- low spilitter cylinder and all orings. But didnt come out to good. Yeah so remove the air regulater and cap. Then take center nut of piston and remove and replace piston oring. If that doesnt work, then you will have to go further in depth, but i have alot of confidence it will work.Air shouldnt be slipping past that
  7. bfroelle
    4
    Nov 3, 2021
    Sounds good! I’ll post on any further updates! Again, I appreciate the help!
    Don379 Thanks this.
  8. Don379
    714
    1,286
    Jan 7, 2021
  9. Don379
    714
    1,286
    Jan 7, 2021
  10. bfroelle
    4
    Nov 3, 2021
    Update: replaced the O rings today and the problem is solved!! I appreciate all the info and help!!
    Don379 and Goodysnap Thank this.
