Eaton 10 speed oil capacity
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jun 7, 2021.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,229
    1,633
    Dec 4, 2019
    Gonna add a pto to my truck and while doing so, I’m gonna change the oil in my transmission. Looking for the capacity of a 10 speed OD.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Fill it until it comes out the fill hole, about 3 gallons-give or take.
    mile marker 27 and jamespmack Thank this.
  4. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Get a five gallon bucket and you'll have a little left over after the PTO is installed to top off your diffs or steer hubs
  5. jamespmack
    213,337
    X2 and cheaper than gallon jugs. Next question brand. Lots of opinions. But as long as it meets manufacturers spec. Your good.
    mile marker 27 Thanks this.
  6. jamespmack
    213,337
    I used to remember all this stuff. But that was running a shop and billing invoices. Now its just full.
    mile marker 27 and Bakerman Thank this.
  7. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    Well, we discussed this the last time I did a pto and the majority seemed to recommend 50wt synthetic. I mentioned that to a very knowledgeable guy who builds lots of dump trucks and own a semi truck salvage yard. I can’t remember what he told me to use but I did use it and I think it was, Mystik 80w-90(old stuff). I’ll have to double check that but I can assure you, I’ve had no leaks and no shifting issues in cold or warm weather. Think he told me, it’s(80w-90) a lot less apt to leak.
    jamespmack Thanks this.
  8. Lazer
    Lazer Road Train Member
    1,728
    2,725
    Jan 22, 2017
    50w synthetic drive line oil.
  9. jamespmack
    213,337
    He is right with older eatons. 80/90 fine. Have had a few customers run it. Really warm up is more important. Let it get flowing. But yearly drains.
    Idk I'm happy with 50w synthetic in a Rtlo and no PTO.
    Still have half a barrel of 85w/140 Hydrotex that some heavy haulers swear by for trailer hubs and rear diffs. They were not looking for fuel milage.
  10. Lazer
    1,728
    2,725
    Jan 22, 2017
    As you are adding a pto, after you fill it, go for a short drive, this give the air in the cooler lines a chance to get worked out. Then park for a spell with everything off and check and top off transmission again.
