If you look at a Eaton 10 transmission it looks fairly straight forward for a transmission. I watched a couple videos on rebuilding one and its
not unlike a car save for an extra shaft. Why then dont these have basic synchros?? Anyone here a mechanic or understand why these cant have basic synchros like cars to make shifting better..?? The RPM on a truck is much lower and would seem to make it even easier for
the ring to grab on and get it spinning before the dog engages..
eaton 10 speed and synchros
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bob888, Jun 16, 2013.
I would imagine that it would be very expensive to make a Sync for a transmission so large that would be under a huge load. Wouldn't it take up space and add weight, too?
jamespmack Thanks this. -
There is a reason truck transmissions don't have syncros in them, The stress would tear them apart. That is also the reason learning to shift a truck takes time.
Synhcros have a bad name here in NA. Largely cos of early models back in the 60's and 70's, in fact I had my driving instructor here in Canada tell me synchros "only last 300,000 kms", nothing could be further from the truth. They are stronger and do last longer however like already stated they are a bit heavier but more compact than you'd think
I don't understand why they don't sell here, Volvo tried to sell them here but sold hardly any, they are so easy use and are a big help in offroad operations- gearchanges are faster, more precise and you can select any gear you want and they eliminate problems especially for newbies on hills, other things I like is the faster progression through the gears from take off, normally a fully freighted truck will go from standing to 60 mph in 4-5 shifts and yes- you can float them -
I guess the reason we don't have synchronizers over here in our class 8 trucks is because we are smart enough to shift gears without synchros
. Where you get that you can float a synchro trans is more than I can figure out. If you don't hit the gear perfectly you're damaging the synchro's now it may be different on that crap ya'll have across the pond but over here it'll tear the synchros up not good
. I wouldn't trust a synchronized transmission in a class 8. The one on my dodge has 215k on it and it's shot...unless it's the clutch but that's got 215k on it so of course the clutch is wore out. Besides that how many truck drivers on the road leave their hand on the shifter when they drive? Quite a few of you know that puts pressure on your synchronizers (so I've been told have yet to see proof) and causes more rapid wear. Now if that is true think about how fast you could wear out a set of synchronizers if a drivers hand sat on that shifter 11 hours a day for 600 miles every day and think of the cost
. unsynchronized transmissions aren't broke so don't fix them:smt115. I would suspect that that is why we don't have synchronized transmissions over here.:smt115
really I sugest it is possible to fit synchro from European Fuller tranny, but you have to install clutch servo becouse it is hard to do clutching every time you shift.
So once again I never said eaton were bad, they are great boxes just synchros are easier to use and nowadays alot stronger -
If you can change gears quicker in a synchro box than a roadranger there is
something wrong with the way you shift the eaton. Every synchro box I have driven in a truck I have had to wait years between changes to get the gear.
I thought you could only get opticruise with the 730hp Scania. Well over you can't get the full manual. -
Over here they'll put autos in the trucks before they put syncros in the trans. I've driven autos, I don't like em. Less than 2 weeks on my own I hardly never use the clutch except to get moving. I'm still grinding a little on my down shifting but I'll get it. My understanding is syncros in the big trucks wont last. And with all the new guys coming to this industry, It makes cense to keep it simple. However more and more trucks are being built with autos because anyone can drive them. Autos are also becoming more reliable and efficient.
I can shift the eaton fine still find a synchro faster and better in deep mud or in very tricky conditions, it's far more forgiving
