Here my first android application
requred Android 2.1+
Easy to calculate recap
download here http://www.freefilehosting.net/hosrecap
just 42 kb
To install you need to check Setting->Security->Unknown Sources (this allow install not from market)
posting on android market now not free, that why it not on market
Easy HoS Recap Calculator for Android
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by alex6999, May 28, 2012.
I use drive axle, some one on here mentioned it and I like it. how does that ap hold up so far?
just found drive axle, its scanner software, not hours calculator, absolutly different application.
for scanning i use camscanner and files anywhere to send fax for free -
There already is a free one on the market
Sent from my SPH-D710 using Tapatalk 2Roadmedic Thanks this. -
Market Recap hard to use, you need manually enter all hours from keyboard.
like huge recap page in logbook.
did you ever use it? It has been used often with old 10/8/norestart rule.
this one can be used even while driving.
I will upgrade this app to allow store work hours in database for every day. -
It keeps saying download unsuccessfully Make a dropbox link and ill download bro and this is the one I've been using
Sent from my SPH-D710 using Tapatalk 2 -
I suppose its not your application. Make your onw and... I will not tell you how its bad, just because you will never make it
So... application updated, now it support resets, on day you finish your reset press and hold by finger and select "Add Reset" or "Remove Reset"
download here http://www.freefilehosting.net/hosrecap_1 -
Make your app downloadable LOL
i couldn't even get the file to download. use a different resource. there are tons of free sights for filesharing.
