Easiest way to remember the Pre-Trip inspection/Outside inspection? Having trouble
Discussion in 'Questions From New Drivers' started by s2kVenom, Sep 15, 2014.
  1. s2kVenom
    s2kVenom Bobtail Member
    19
    Aug 12, 2014
    Ok guys I thought to postpone my test which was supposed to be wednesday this week cause I wasnt confident enough and dont have the whole pre-trip inspection down. I know the air brake test is easy but Im having trouble with the outside parts. I currently have a video from my school which I try to watch over and over again but theres so many parts to name and talk about. How did you guys get ALL this info down?
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    at school we started every day with a pretrip
    you didnt drive until you got it right
    practice and move from one spot to the next same way every time
    Dan.S, ncmickey, Puppage and 1 other person Thank this.
  4. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    They should let you go out to the truck after school? Go out there with your list and practice it til you know it.
    dennisroc Thanks this.
  5. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Simple, start at the front bumper and name everything you can see one at a time, checking for Not Bent Cracked Broken Loose or Leaking, and propperly secured. Fluid Levels are full and not leaking. Then repeat until the insprctor says enough.
    harlycharly55 and kemosabi49 Thank this.
  6. RoadCall
    RoadCall Road Train Member
    1,490
    935
    Mar 12, 2012
    Exactly! ... Nothing specific to remember just name everything in sight! That's what I always told my trainees. Don't sweat it, cover everything!
    x1Heavy Thanks this.
  7. TruckerGonnaBe
    TruckerGonnaBe Light Load Member
    140
    38
    May 27, 2014
    Western WA
    What worked for me was to write it out in the sentences I would use during the test. As I corrected the sentences I rewrote the whole thing back out. I also compared those notes to pictures I took of the truck.
    Repetition was the key. I had my classmates do the same thing. In the end everyone passed with flying colors. I missed 10 due to nerves but they said later I could have missed up to 26.
    I still use that pre-trip. ;-)
    Dan.S Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,526
    13,261
    Jul 6, 2009
    yep, you basically have to look at everything.
    cracked frame, rubbing air lines, right down to the shock bushings and all other bushings.
    the frame part doesn't happen much but it does happen. air lines are important as that's the biggest cause for out of service inspections, along with brakes out of adjustment or worn down.
    when hiring on with some companies, they'll actually take you out to a truck and listen to your inspection. you don't necessarily need to check. but if you don't name ALL the fluids. you won't get the job. i know a friend that didn't get hired on with a asphalt company because he said nothing about checking the oil.
  9. harlycharly55
    harlycharly55 Medium Load Member
    608
    513
    May 5, 2014
    Houston, TX
    "checking for Not Bent Cracked Broken Loose or Leaking, and propperly secured. Fluid Levels are full and not leaking." this is what I did at the DMV and as I got around the front to the drivers side the Tester said OK, skip this get on to the important things!
  10. thejdogg
    thejdogg Light Load Member
    56
    28
    Oct 26, 2013
    Missoula, MT
    Are you watching the video straight through every time? That's too much info to absorb at once. I'd recommend letting it show the first section, pause it, and list off the names of parts and things to look for. Play it to see if you are correct. Repeat til you get it. Then add the next section just like you did the first. Focus on that section and learn it. Now start from the first section and work your way straight through the second. Only when you got everything down in both sections should you move on to the next one. Keep breaking it down like this til you got it all memorized. It will take a lot of time like this because you will start from the beginning and repeat a ton of info, but you should get it down. If you can do this a couple different times over a couple different days.
    Optional:Once you get all of it down and have some extra time and aren't burnt out, mix it up if you can. Start halfway through and see if you can nail it. Skip around. It really hammers things into your memory and shows you which things you are still a little rusty on.
    Good luck
  11. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    How about bee bopping on down to a truck stop and see if a driver will let you study from his rig.You need some hands on to really understand the pretrip.
